Question about eMachines Computers & Internet
I installed a new screen to my emachines laptop then a windows failed to start screen appear, i don't have the cd for boot...
    New Friend:
  • 51 Answers
Restart your pc and press f8 before windows start select safemode and you can run your recovery from there...good luck..tekgods.com
Posted on Oct 26, 2013
aminic
  • 61 Answers
SOURCE: acer 7520 does not boot
Find out if your computer's processor is X86 (32bit) or X64 (64bit) then use the right "bit" installation CD.
Posted on Sep 20, 2008
ChipcircuiT
  • 157 Answers
SOURCE: Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Posted on Jan 05, 2009
  • 9 Answers
SOURCE: laptop won't boot into bios or windows
You buy a new laptop. Sorry. Being a little facetious there, but the reality is unless you are used to working on laptops (as I do for a living and I HATE eMachines/Gateway units, they're right up there with Toshibas and Apples) this is a little beyond the average hobbyist. You have to remove the hinge cover and top bezel (above the keyboard), then remove the keyboard, the LCD, the top case assembly, and then finally you MIGHT be able to get the CPU out though there may be some other small parts to remove first. Bear in mind if you try this at home that you may damage a component by simply slipping and that could render your new laptop useless.
I don't have a schematic or service manual handy, but again I say take it to a pro, you will save yourself a lot of time and pain, trust me. All of this is assuming that you can find a CPU that will work properly with your system, it may be maxed out already.
I can't stress this enough, this is not an upgrade that I would recommend you try as you probably won't benefit from it and is not one that should be done by the average laptop owner, desktops are A LOT EASIER to do this specific upgrade to. Sorry if I sound like a wet blanket, but I am trying to prepare you for the reality that may lie ahead of you if you decide to go ahead with this.
Posted on Mar 19, 2009
  • 145 Answers
SOURCE: i want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
Posted on May 02, 2009
SOURCE: emachine E525 was fully locked
não consigo de jeito nenhum achar o drive de rede para o emachines e525
Posted on Jul 13, 2009
Emachines E528 laptop won't start
Try to boot it from safety mode.
and try to restore your system first.
If the restoring is failed, boot safety mode again and back up your files.
If you can't boot your laptop from safety mode, use anti virus program CD like norton.
Mostly, your system is messed up by adwares, spywares, and virus.
If all things fail, you should check your HD.
Jun 18, 2013 | eMachines E525 D260 Motherboard...
Error 0xc000000f while formatting hard drive
try some formating toos .. like hiran boot cd or disk or diskformater ...u can use usb bootable device to install windows, u can make ur personal pen drive to bootable pen drive.
Jun 02, 2013 | Packard Bell Computers & Internet
I have a emachine e528 laptop when I cut my computer on it just shows a blinking white underline in the top left corner how do I fix this?
First things first. Make sure you don't have anything connected in the USB sockets or the bays (CDs etc). Disconnect from the charger and also remove the battery. Hold down the 'on' button for 10 seconds...this will reset your laptop. Reconnect to power and try to switch on again. If the laptop still doesn't function it may be a RAM problem or a hard disc problem (you can try removing and re-installing both). It's worth trying a Windows installation disc to see if the laptop can boot from that. If it can, that will prove your RAM and motherboard is OK and indicate a problem with loading Windows. You don't say whether you get any 'splash' screen....that's the one that usually gives the manufacturers name briefly. If you don't even get that, it could be a bad omen. If you can get the Windows installation disc to boot, you can do a repair installation. To do that you go right through the installation procedure until you get the prompt asking you if you want a new installation or repair installation. This is different from the Repair Console- don't select that. You may find that the installation fails because the hard disc is no good. In that case you will have to transfer your data onto a new disc, there's free software to do that (you will need another laptop or PC)
Sep 26, 2012 | Computers & Internet
Can't install windows
If there is a boot menu you may have to load the CD drive from there and the restore disk will load. Check the boot screen when the PC is first turned on and look for restore option and which key to press. It is usually F10 or F11. If all else fails press F8 on start before the first boot screen vanishes and select the prompt option. then load the CD from there after you ID the drive letter.
Sep 16, 2012 | E-Machines eMachines Desktop PC
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
Non-System Disk or Disk Error Boot from CD
The error means that the CD you have in the drive is not a system disk. Remove it. Are you trying to boot from a CD, if so make sure it is a repair disk or operating system disk. If not, remove the disk and you system will then look to boot from the Hard Drive.
Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 30, 2012 | E-Machines eMachines Desktop PC
Window 7 won't boot up
BECAUSE THE FIX IS LONG GO TO http://windows.microsoft.com/en-US/windows-vista/What-to-do-if-Windows-wont-start-correctly
Apr 15, 2012 | Computers & Internet
Emachines W3619 won't load ntldr
Take a windows XP CD, Switch on your PC and go to "BIOS" menu and select "Boot From CD/DVD" whichever is applicable for your pc.
Now insert the Win Xp disc i drive and start PC, Boot the Pc From CD Drive and you shall get the Blue screen of windows Installation. Restart the PC by hard pressing the power button for 30 secs.
Now you will be able to login to windows.
Dec 02, 2011 | eMachines W3619 PC Desktop
I would like to wipe out my computer and start over can i do that
Hi josephamy99
Yes , you can . Launch the install disc and follow instructions .
Note : back up all your data and drivers ( very important , the drivers , some hadware could not function if you don't reinstall the drivers on your new system ) .
Best regards ,
fanaudi .
Sep 14, 2011 | E-Machines eMachines Desktop PC
I add downloaded messenger to my emachines ET1641-02w
e machines have problems like this. unplug it from the back of the computer for ten seconds, plug it back in, do a start mode> If this does not work try rebooting to an earlier time
Jan 09, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
44 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
