Question about Logitech X-540 Computer Speakers
Color wiring diagram of alteclansing vs221 speakerkcof speaker altac lansing vs221
What is the highest room temperature that you can use the 2.1 speaker without danger of overheating?
That's a scary question. And there's more to it than ambient room temperature. Proximity to heat sources and availability of ventilation play into it. I imagine if your PC can survive the environment so will the speakers.
http://www.alteclansing.com/ae/us/computer-speakers/vs4121/invt/vs4121
If you really need a number you should contact the maker.
http://www.alteclansing.com/ae/us/page/contact/
800 258-3288
866 570-5702
Jul 21, 2011 | Altec Lansing VS4121 Speaker
I have lost the cable from the back of the speaker to the power socket. Any ideas how to get a replacement?
Hi there , not long ago I was having issues with my VS 2420 I wasn't getting any replies to my queries when requesting help through the web site then someone forwarded me the following Contact: nicky.cook@alteclansing.com , seems to be manager customer care I got a reply within 24 hrs and a new one was shipped to my UK address within 58 , awesome service ! :D
Mar 19, 2011 | Altec Lansing T612 - High End Speaker...
Is is possible to install altec lansing speakers
It is possible to hook up these speakers to a laptop according to this brochure:
http://www.alteclansing.com/images/spec/vs4121%20sell%20sheet.pdf
Now this manual shows those speakers being hooked up to a computer but laptops have the same outputs as well so here it is:
http://www.alteclansing.co.uk/images/quick/vs4121qcc.pdf
you'll need adobe reader to read the manuals.
May 17, 2010 | Altec Lansing VS4121 Computer Speakers
Lost my cd installer need something to help
crazy, the speakers itself does not have drivers, but altec lansing does have utilities to optimize your speaker powers. you may also want to update your sound card's drivers.
http://www.alteclansing.com/index.php?file=north_product_detail&iproduct_id=vs4221
regards,
voodoo
Apr 12, 2009 | Computers & Internet
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
Hi
Looking at the manual http://www.alteclansing.com/downloads/EUR/VS2121%20manual.pdf page 3 of the pdf says Connect the lime green 3.5mm stereo cable (hardwired into the right satellite) to the lime green input labeled ?FRONT? on your sound card. So your right speaker should have a cable with a green end that plugs into your standard audio out jack If you have multiple outputs and don't know which you are set up for, then turn the speakers on and up, put a long song on, and plug that green wire into every jack on the PC! If you've got no other issues you'll hear something! Good Luck
Aug 28, 2007 | Altec Lansing VS2121 Computer Speakers
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Logitech X-540 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
