When i turn it on the screen stays black and there is a high pitch sound emitted.
    Problem Solver:
  • 13 Answers
I think tht th picture tube of ur t.v got wrong.get it changed n it wil start working.
Posted on Nov 29, 2012
SOURCE: High pitching sound
buy a new tv
Posted on Jul 26, 2008
  • 6 Answers
SOURCE: syntax olevia lt32hv 32 inch lcd tv. power surge now no picture
The electronics are known to go bad with these TV's, and I'm looking to buy someone's junk TV that has a good screen, rather than have to throw it out.
(So if anyone is out there with a 532-B12 that isn't working, send me a message!)
Yours might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact.
If you DO manage to contact anyone (manufacturer or otherwise) who can source or supply parts, PLEASE do let me know - it's been nearly impossible for me, and I want to replace my cracked screen in my TV.
If you can't, please let me know - I'll gladly give you a few bucks at least to salvage the screen from your TV, to transplant into mine, rather than turning it into junk on your curb.
Posted on May 17, 2009
SOURCE: Soyo 32" won't turn on
The problem is the capacitors on the power supply board. There are two of them, the rating is 220uf - 250v - 105C (M). The back side of the capacitor says V9A PET. You need to remove the board, make sure the capacitor is drained, (you can do this by placing a screwdriver across the posts) Use a soldering iron and remove the capacitors. The only place that has replacement parts is at www.mouser.com, Install them, make sure the polarity is correct, re-solder them back into place. Re-connect the board and it should power back up correctly. Good Luck. Steve
Posted on Jul 27, 2009
johnnydiode
  • 647 Answers
SOURCE: Panasonic TX32POL1 high pitched noise
The high pitch sound is comming from a power supply transformer that will resonate (or vibrate) at the operating frequency (12-14KHz).
This is usually affordable to repair -at least worth the estimate.
Posted on Oct 14, 2009
vinnyq
  • 157 Answers
SOURCE: When turned on picture fluctuates and emits hig
The high pitched noise is coming from the Tcon board. It is not properly decoding the signal coming form the main board correctly. The only way to fix it is to replace the Tcon board. You might have a hard time coming across the part because Olevia has since gone out of business. Also, usually Tcon boards are not available sepertaly and most manufactures make you purchase the whole LCD panel of which the Tcon is included.
Posted on Nov 09, 2009
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Need help with blank TV screen after replacement of control panel
The new board may be causing this--either defective or the set needs a reset of some type---get the board from Samsung or where?
Jun 15, 2012 | Samsung LN40A500 LCD TV
I have a Sony Wega KDF-E50A10 TV, and when I turn it on, the screen stays black and it makes a high pitched sound. Please help.
that high pitch sound is comming from the HV capacitor in the power supply.only a tech can remedy that problem.kindly take it to a tech for repairs.
Sep 25, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
View sonic computer screen was dropped and now when you turn it on the picture comes on and then it emits a high pitched sound and turns off. any suggestions?
Sounds like you may have broke at least one of the lamps . The high pitch sound you are hearing is the high voltage that goes to it .
Feb 05, 2011 | ViewSonic OptiQuest Monitor
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
After a power problem, tv just emits a high
hello there's a couple of things that could have happened 1. of the capacitor may have blown and 2 the convergance ic have blown which could have taken out the resistors in front of the ic
regards
shaun
Apr 03, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Won't turn on.
Thats sound it's because the horizontal IC are in bad conditions and need to replace it.Good luck.
Jul 25, 2008 | Televison & Video
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
