Question about Marantz CDR632 CD Recorder CDR-RW with Manual Track Increment
Marantz CDR632 keep saying Can't Edit.
I am trying to delete tracks on a cds but it keeps saying Can't Edit. I am using CD-RW and it should be rewriteable. How do i fix this?
    Sergeant:
  • 344 Answers
There has to be a problem with the recorder, If you have a computer with a cd burner try it,
Posted on Nov 29, 2012
  • 3422 Answers
SOURCE: Marantz CD-5000 CD player
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
Posted on Feb 22, 2008
  • 9 Answers
SOURCE: I have a marantz cd re-corder but I insert a cd rw disc or cd r
check the manual for what types of discs you can use.
Posted on Jan 15, 2010
SOURCE: I have a Marantz CDR632 and I am recording sermons
We have the same problem with our CD duplicator at our church. When the duplicator finishes it always shows 'fail' but the copied CD-R appear to have copied correctly and play on other players.
Posted on Mar 25, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Marantz dr
CD-R's must be made for and imprinted with the words "digital audio". Blank DATA discs will not be used. Do you have the manual?
http://www.retrevo.com/support/Marantz-DR6000-manual/id/511bh840/t/2/
Posted on Jul 16, 2011
SOURCE: I own a Marantz CD-5000
its best if you let a professional tech work on it beause there tools that need to be used to check where the problem came from.
Posted on Aug 01, 2011
Need Manual for Koss CDR600
Try owners-manuals.com and if that is not there then do a search on the internet as well as the manufacturer website.
Dec 08, 2012 | Marantz CDR632 CD Recorder CDR-RW with...
It no longer reads all cds sacds it use to, thought cds were bad,bought second cds and still will not play help love the sounds
When you say it doesn't read SACD's do you mean it doesn't put out 5.1? Keep in mind that you have select the SACD multichannel area and use the 5.1 analog outputs for that and NO digital output will be produced.
The manual...
http://www.retrevo.com/support/Marantz-SA8260-manual/id/511bh850/t/2/
Dec 28, 2010 | Marantz SA8260 CD Player
I have a Marantz CDR632 and I am recording sermons for a church. After I am finished and completed the finalization process I try to use in a duplicator and it gives an error message that it is a problem...
Feb 26, 2010 | Marantz CDR632 CD Recorder CDR-RW with...
On my Marantz CDR-630, how do you erase unwanted tracks after recording and before finalizing. I see there's a "erase" button but it won't do anything. Fred, fred@katli.com Thanks!!
Which recordable disks are you asking about? "Erase" will only work on CD-RW and does nothing on CD-R.
Once you've recorded onto CD-R all you can do is add additional material to it until the disk is finalised to allow it to be played on virtually all CD players. The same goes with CD-RW, but with those you have the option to erase the entire disk and start again from scratch. You can also delete individual tracks from a CD-RW but the space does not become available for additional recordings until the disk is totally erased.
Perhaps you'll find the .pdf manual to be of use:-
http://www.vegalab.ru/forum/attachment.php?attachmentid=65482&d=1256129031
I hope that this has answered your question, all I ask in return is that you return the favour by rating my answer.
Nov 05, 2009 | Marantz CDR631 CD Recorder
Tracks too short to to create CD from hard drive.
either have to delete the short tracks from playlist to burn...when i get mssg theres usually nothing there (hit new track 2x by accident, just silence) Or if u want what is on the short tracks, have to join it to longer track b4 or after it, making one longer track, and no more 1 sec track...to do: hold playlist edit and delete track button, will ask if want to join two tracks, say yes and its done...When u do this, the track you do this on will b joined to the previous track, it will give u mssg showing which two tracks about to join and what track name will b left...(for example do u want to join track 01 to track 02...resulting track name will b track 02)..can then burn once all short tracks either deleted or joined to larger tracks...
Apr 03, 2009 | Alesis MasterLink ML-9600
Marantz CDR633
Try the following link.The manual will be automatically downloaded once the link is clicked.
click here for the manual of Marantz CDR
Good luck.please do rate my answer if accepted.Also feel free to post further comments.
Jan 18, 2009 | Marantz CDR632 CD Recorder CDR-RW with...
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
