Question about Sharp LC-C4662U 46 in. TV
Replaced inverter boards on sharp 46 aquos but nothing
    Top Expert:
  • Sharp Master
  • 74,251 Answers
After replacing power inverter board, there are so many adjustments should be done. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 29, 2012
  • 53 Answers
SOURCE: My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Posted on Mar 14, 2008
tray06606
  • 59 Answers
SOURCE: cracked screen on 46 inch lcd sharp aquos
hi you looking at 1400 for just the screen if you had your tv less than a year then you are covered for one year by sharp so what i would do is call sharp and see if your covered on cracked screens
Posted on Jan 10, 2009
MNfisherman
  • 11896 Answers
SOURCE: sharp aquos 46 picture disappears intermittently
it might mean there is an intermittent connection or cold solder joint somewhere inside the set.
But I wouldn't just settle on that.
Here are some other things to check:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Here is what I suggest:
ONE: Give it a hard reset. Possibly the software codes in the power management are corrupted. Just unplug the tv line cord for 4 hours. That will reset everything internally to factory defaults.
TWO: Give it the old whacking test. Just bang on the cabinet in many places with your hand or fist. That will restart any cold solder joints or loose connections.
THREE: If the above procedure does not help, then you will have to call in an expert tv tech; OR just live with it and put in a line cord switch so that when it is OFF, it is really OFF.
Posted on Jan 17, 2009
  • 50 Answers
SOURCE: Sharp Aquos LC-46D64U need to replace broken tuner
actually you dont need the tuner you just need the rf connector itself which you can easly pick up at a radio shack for a few bucks. you can DIY it will take a bit of soldering and time. First take the broken connector to radio and look for a close match, longer leads better you can always cut to fit.
remove board from tv and un solder the tuner. if solder does not seam to melt apply some fresh solder and then unsolder. pop the tuner lid of carefully both top and bottom to gain access to the circuit. cearfully remove any remains of the old connector. Now find the hole where the last part was and insert new RF connector adjust and cut the lead if nessary and resolder to circuit. place both caps back on and resolder tuner to board.connect board to ther circuit and test.
Posted on Mar 18, 2009
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
The power is open but i don't have a picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Sep 05, 2016 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sharp Aquos LC-46LE830U. The white link blinks and there is no picture or sound. I did the reset. It turns solid and picture comes back, but goes out almost immediately.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 02, 2016 | Sharp LC46LE830U - LC 46LE830U - 46 Aquos...
Sharp aquos 46 in
Check its fuse at the power supply board. If found burned, make sure that there is shorted component/s. Try to repair it. If the repair cost exceed than the cost of a new one, replace it as card basis. It will be more better than try to repair these boards.
Contact the authorised service center for Sharp, to buy a new one.
Jun 07, 2012 | Sharp AQUOS Blu-ray Disc Player
Looking for solution for Sharp Aquos LC32D41U 32 "
when it goes black then check with flashlight 2 in from screen and see if you see a picture, if so then inverter board is going out, you can google your model and inverter and find the replacement.
Dec 30, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
52inch Sharp Aquos has a constant blue blinking power on light no picture at all.Tried the resets,still the same,installed new inverter boards,still the same.Now what?
This problems is not those 2 long LCD inverter boards problems,why did u replaced those 2 long LCD inverter boards?I fix this problems before for a 46" LCD Sharp Aquos L46D55U tv.This problems,it the Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 08, 2010 | Sharp LC52D65U 52 in. LCD TV
My 46 in sharp aquos has sound and no picture. what's up?
Dead 24vdc power supply or dead backlight inverter board, you need to do in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Aug 20, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC C3234U screen goes black, audio is still good, turn to another channel far away from the intended channel & it will reset. More often as time goes on.
Ur LCD inverter board it dead,replaced this LCD inverter board will get ur picture back.It long board in shape.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.
Mar 31, 2010 | Sharp Aquos LC-C3234U 32 in. LCD TV
The power light on my sharp aquos blinks green and the tv will not turn on. help!
TV detected lamp error, problem could be either INVERTER UNIT or one of the lamps. Defective part has to be replaced, lamp error counter reset.
Nov 13, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Jun 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos 46'' suffered lcd death
YES. REPLACEMENT BOARD RUN ABOUT $150-$250 FOR THAT SET. MAKE A LITTLE CASH ON THOSE BOARDS.
Jan 01, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC-C4662U 46 in. TV Logo
83 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
