Question about Panasonic KV S2065W Path-Through Scanner
Always show code u18 paper jam inside scanner, but check no paper, sensor, mother board changed. problem still show the same problem u18.
2 Suggested Answers
  • 40 Answers
SOURCE: I am getting a u18
You have reached your limit on color copies that the key operator has established for your code.
Posted on Mar 08, 2011
Keeps saying there is a paper jam and there is no paper jam what so ever
Still the logic board thinks there must be a paper jam. Could be caused by a defective sensor, bad connection from sensor to logic board or a defective logic board. And what is very common, something dropped in the printer and really blocks a sensor.
check all places where the paper can go, if perhaps a paperclip or a little scrap od paper is blocking a sensor.
Or contact a service centre, or perhaps you start sving for a new printer?
Apr 26, 2015 | Brother MFC-290C Printer
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Hope the above info is helpful.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
U18 remaining doc. error code;
The sensor that you can't see (at the bottom facing up) needed to be cleaned. Once cleaned with a cotton swab and alcohol the scanner works fine.
Apr 03, 2009 | Office Equipment & Supplies
Error P00 on display, no paper jam found
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
Scanner Error power on power off
there is a sensor in the paper feeder tray which is also connected to the scanner area that sensor is bit moved from its orignal position or is slightly broken while the paper jam or while removing the paper jam.
please check the sensor.and make it proper.the error will go.
Oct 05, 2008 | HP LaserJet 3330 All-In-One Printer
Scanner Display Shows False Jam
You can try 1. reseting the scanner 2. uninstalling and reinstalling the software
PLEASE don't forget to RATE ME (FIXYA) for my help..........
Aug 15, 2008 | Fujitsu fi-5750C Flatbed Scanner
Paper jam
check all the paper sensors see if the sersor arm are still in place, clean all the sensors usually a photo diode type located at the boards.
Jul 29, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Kodak 2500D error
I have had the same problem. That error represent a document still in the scan path. You will probably find there is no paper in the scanner. I tried this and it works every time. On the top of the scanner there is an access door. You will find this just above the discharge rollers. Open that door and either blow air in the compartment or blow hard using your mouth to clear dust. Close the door. That should resolve the problem. It is my guess that dust collects on sensors and the scanner is tricked into thinking there is paper in the path.
Jan 04, 2008 | Kodak Digital Science 2500D Path-Through...
Panasonic KV S2065W Path-Through Scanner Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
