I have a heat pump and a new condenser Payne made by Carrier was installed 7/12. My problem is I live in east coast and I notice that the condenser is on but the fan doesnt turn on in synch with condenser. Called a contractor but they said it is motor problem in the blower and it was changed. That didnt solved the problem,I notice that the condenser will turn on and the fan will turn on maybe after 10 min.Need some advice pls.. t
  • Heating & Co... Master
  • 1,610 Answers
Your system likely has a thermal sensor in which the fan kicks on on a as needed basis. Normally this will happen during the heating cycle. Are you heating or cooling?
Posted on Jul 08, 2017
  • 182 Answers
SOURCE: Carrier Synergy 2000 Condenser fan does not turn on
the mfd is stamped on the side of the capacitor.Be careful to kill the power and to NOT touch the terminals.The capacitor is capable of holding a charge even after power is disconnected.
Posted on Jul 29, 2008
kentguidry
  • 51 Answers
SOURCE: Need help selling a Carrier 4-ton 10SEER unit!
Yes you can sell this unit. You would have better luck posting on ebay or craigslist.
Posted on Feb 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: HVAC Blower Motor Replacement
Ain't nothing to it. Slide out the blower and take it outside. Use some rust buster to get the blower out. Don't beat on the shaft. Spread that shaft and the wheel won't come off. Use a rubber mallet. Most generic blowers have white as a common wire and the speeds are black-hi blue med and red, for low. 2 brown wires will go to the capacitor. other wires will reverse direction. Wash the housing and blower wheel good. any wire unused will be taped off to themselves. Nothing to it.
Posted on Mar 11, 2010
  • 146 Answers
SOURCE: Goodman 3 ton heat pump - condenser fan motor gets
did you get a motor with the same amps? did you check to what the amp draw is on the old motor to the new? reason is different amp ratings on motors need dfferent blade pitches, also 2,3 or 4 blades pull different cfm. is the motor a belly band mount or does it hang by studs? also check to see if the capacitor is the correct uF. hope this helps you feel free to ask any question if this does not help you.
Posted on Jun 09, 2010
  • 133 Answers
SOURCE: I just had a new Dometic roof air conditioner
I have over 35 years in the A/C business and am ASC certified. The motor will normally draw 4 to 6 times it FLA (Full Load Amps) or RLA (Regular Load Amps) when first starting up or is seized. This is called LRA (Locked Rotor Amps). These specs can be found on the motors nameplate and can be checked with an amp meter. If the motor hums and won't start while pulling these high amps, Try giving it a spin with a stick. (in the right direction of course). If it keeps running when helped to start, its probably the capacitor. They normally run about $7.50 wholesale. If its tight in both directions while humming, 1 or more of the field poles is out of balance and the motor will need replacement. Good luck and be careful when spinning it.
Posted on Mar 31, 2011
Testimonial: "Thanks the RV shop wo installed it are going to contact Dometic and He thought the same as you. Thanks!"
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
Aug 30, 2017 | Bryant Heating & Cooling
Where can I buy an aircondition condenser motor fan- carrier brand
Any carrier or payne dealer , or A/C supply house . If you tell me where you live I can give list of suppliers.
Oct 02, 2014 | Carrier Heating & Cooling
How do i fix my fan speed problem. I lost 1 of 2
It may be a defective switch, loose or corroded contact connection point, where the wire meets a terminal. If these check out good, then the fan motor is defective and needs to be replaced with a new one.
May 29, 2014 | Coleman Mach III Air Conditioner
Air conditioner blowing warm inside and cold outside
it's a heat pump in the heat position . Check the thermostat to see if it's in the heat position. If not then the changeover valve on the unit is stuck.
Feb 08, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Filter for Payne (Carrier?) Heater FB4CNF024??
Yes what you say is right try home depot ,canadain tire, lowes, they all do filters with differant sizes you can get them in 12 , 10 what ever you need
Feb 17, 2012 | Heating & Cooling
I have 4 ton carrier heat pump / puron. It is a new system been installed about 3 months. Live near Dallas Texas and lately the temp has dropped into the low 40's at night. The heat seems too be working...
The water is from humidity in the outdoor air which has condensed and then frozen to your heat pump outdoor coil. The heat pump will defrost occassionally, depending on how much frost has accumulated to the coil and will then generally drip off the unit and onto the ground. This is normal. To keep the water off the drive way may mean having to move the heat pump to a place where the condensation can run away from the drive area. Or provide some other means of redirecting the water.
Nov 20, 2010 | Heating & Cooling
Have a Payne A3PZ airconditioner and a Roberts Aire thermostate need help with wireing it up. The was I understand is that you need a Payne therostate to use with Payne AC unit. But surely there is a...
No, Payne is a cheap Carrier unit. Keep track of your wires and what terminals they are attached to. Usually, units are either a 4 wire or 5 wire setup. In either of these the R terminal is your 24v power, G term is your fan, W is your heat, and Y is your cool. Some times there is a 5 wire which is your common. You use a common if your thermostat isn't powered by a battery. On the R terminal, they are usually marked RC/RH and have a jumper between them. The only time you should remove the jumper is in a 5 wire set up. RC refers to the common and RH refers to Hot or power. Make sure that when you are installing the new tstat there is usually a very small switch that you change for either an electric unit or a gas unit. Change according to what you have. As long as you keep track of your colors and terminals on your old tstat, you won't have to open up your unit to see where the wires are terminating. Good luck to you!
Mar 22, 2009 | Heating & Cooling
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Gas tank
The wiring is for the fuel pump and fuel regulator,I would suggest,you take the fuel pump assembly from the old tank and use it in the new one.
Or if you can post year and model of the vehicle that the old tank and new tank are from or for,I can locate a wiring diagram.
Please rate this a fixya
Jan 26, 2009 | 2000 Kia Sportage
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
