Washer will not fill when I start the cycle
SOURCE: Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
SOURCE: Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model #
Please rate this,Thank u
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
SOURCE: Water will not stop filling the washer
I just fixed this problem on my GE washer that overflowed earlier into my hallway and living room. The fix required removing the tube from its connection at the outer tub and cleaning out some residue that was preventing air from moving to the sensor at the top of the machine at the control panel. No tools were needed other than a large steak knife to undo the clips to remove the front panel of the machine and a small flat head screw driver that I used to clean out the plastic pressure hose.
The good news is that even if this had not worked and the sensor/switch needed to be replaced, the part is available for replacement at the local hardware superstore and a few online outlets for around thirty dollars. Replacement of the switch looks to be relatively simple by disconnecting the existing wiring housing and replacing with a new part.
There are several detailed diagrams available online by doing a search for your product/ model number.
Be sure to check the hose before replacing the pressure sensor/switch- this will save time and money.
SOURCE: Washer starts agitation during water fill up and
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
the model number is 110-20022012 I turn timer to wash and water does not fill. then it starts washing with no water
