Question about Asrock P4VM800 Motherboard
Asrock P4vM800 no audio or video
The system powers on but doesn't beep when ram is taken out and when ram is installed no beep and no display from the on-board VGA or the AGP 8X connection....Can anyone give a solution to this prob..
  • Asrock Master
  • 3,606 Answers
Hello you can download a manual here:
http://www.asrock.com/mb/VIA/P4VM800/?cat=Manual
You need adobe reader to read the content.
My guess is the power supply is failing try to change
it with one you know works.
Look also for bad capasitors on the mainboard:
They should not look like this.
If this is the problem the mainboard must be replaced.
It will exeed the price for a new mainboard to let them be changed.
Good luck
Posted on Nov 29, 2012
SOURCE: bought agp video card x1550 256mb ddr 2 by visonek not working freezes at bio
hi skinny! that problem is you have a 775VM800 which is only compatible with agp ddr video card not ddr2. you need to buy an adapter with max of 256 bit. here, i'm using inn3D G-force fx 5500ddr 256 (128 bit) and it works perfectly. just e-mail if you have to asks something. coolwayne71623@gmail.com.
God Speed!
Posted on Dec 03, 2008
syedmujahed
  • 158 Answers
SOURCE: CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Posted on Sep 27, 2008
map9966
  • 2351 Answers
SOURCE: error signal ASRock P4VM800
When you open to you're bios menu, either at the top or at the bottom of the screen will be a name of you'e bios. In you're case the name is at the bottom of your bios menu. (American Megatrends Inc.). Or for short AMI You could search google for, AMI bios beep codes.
And you can click on this link, which shows what AMI say's about 3 beeps.
http://www.bioscentral.com/beepcodes/amibeep.htm
You need to test you're memory. (Only if cleaning the memory has did not change the beep error beeps).
First remove you're memory & blow out the DIMM slots with canned air. Clean the copper on the memory with house hold alcohol on a lightly dampend cotton swab. (Let it dry), (Do not touch the copper with you're fingers. Re-install you're memory.
If you have more than one DIMM. Remove the bank farthest from the CPU & boot the PC. Did you hear the 3 beeps? Remove the the next bank & re-install the one you removed first in to the slot closest to the CPU. Boot the PC, again did you hear the 3 beeps?
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Posted on Apr 27, 2008
rajeshpait
  • 542 Answers
SOURCE: getting on board vga video to work on asrock
As per discription provided by you, Suspect the physical RAM is having problem. Check and insert the RAM properly may solve your problem.
Hope the above solution may resolve your problem. Please give us the feedback on the solution to provide the best resolution in future.
Revert Back for more assistance or clarifications.
Posted on Dec 26, 2009
  • 67 Answers
SOURCE: asrock p4i45gv not detecting hd 3650 agp card
Take the new card out and reconnect the monitor to the on-board VGA. Boot up press F2 and enter the bios. Look for resource configuration and set the Primary Graphics Adapter as AGP.
Save and switch off. Disconnect the PC from the mains, fit the new card and attach the monitor cable to the new card.
Make sure to attch a power connecter to the card if it needs it.
Reconnect the PC to the mains switch on and hopefully away you go.
Best of luck.
Posted on Jan 29, 2010
Installed ASRock motherboard and it doesn't even try to boot?
Check the RAM modules, it maybe faulty or the wrong type.
Oct 19, 2012 | Asrock AM2NF4G-SATA2 Motherboard
Motherboard asrock P4VM800, we have checked and replaced everything with known good Ram, PSU, heatsink. We have confirmed that everything is connected correctly. when you power on the unit the cpu fan...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 05, 2011 | Asrock P4VM800 Motherboard
System is running , fan cd room all are ok but no any display on monitor . What may be the problem?
hook up speakers to the mother board when testing see if you get any beep codes ram not seated properly will cause you to have no video. The beep codes will help you know the problem.
May 04, 2011 | Asrock P4I45GV R5 Motherboard
How to install ASRock P4VM800 Audio Driver in winxp
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 24, 2010 | Asrock P4VM800 Motherboard
No display
check with ram and power supply.
Mar 10, 2010 | Asrock P4VM800 Motherboard
P4vm800 not working how to solve this probelom
Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
  1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
  2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
  3. A keyboard.
  4. If your motherboard has no VGA onboard, A good VGA card.
  5. A thumb speaker, or you can use your PC case speaker.
Okay lets assemble, on a table:
  1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
  2. Connect the pc thumb speaker or your case speaker.
  3. connect the keyboard.
  4. connect the RAM, make sure it clicks as you install it.
  5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
Also check out the PC speaker beeps.
  • 1 beep mean good.
  • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
  • Continous long beeps. cannot detect memory
  • Continous short beeps, motherboard. (or memory sometimes).
  • No beep, fan is on.at this point do everything again. (do it several times until the board responds)
Hope this helps you. feel free to ask again.
Oct 14, 2009 | Asrock P4VM800 Motherboard
CPU OR Motherboard
Sep 27, 2008 | Asrock 775VM800 Motherboard
Asrock motherboard
Look HERE for a list of bios beep codes
May 18, 2008 | Asrock P4VM800 Motherboard
Error signal ASRock P4VM800
Good Luck!
Mike
Apr 27, 2008 | Asrock P4VM800 Socket478/SAT/A&V&L/Modem...
Driver for Asusrock p4vm800 Motherboard...
Found these for you.. and a Manual also. www.asrock.com/support/download.asp?Model=P4VM800 www.judiciary.go.th/techno/Replase-Computer/48-supreme/P4VM800.pdf
Aug 15, 2007 | Asrock P4VM800 Motherboard
Asrock P4VM800 Motherboard Logo
260 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
