Question about Toshiba Satellite A105 Notebook
Laptop battery battery is brand new and still it will not hold the charge
  • 93 Answers
Hi, if the supply is an original toshiba and does not load you must check yourself in the page of toshiba to seeing if this one inside the battery packaging that estan affected and that must change, if the case is not this and the battery packaging does not take load you must check if the previous one at least takes something of load and of this form you certify that the battery packaging is that of the problem.
Posted on Jan 14, 2009
New battery won't charge
There is a chance that the charger is broken. Some batteries need to be jump started (charge it for some hours), especially an old battery (the brand new battery but it does not hold charge for a long time)
Feb 17, 2014 | Computers & Internet
Laptop won't charge battery
Laptop battery problems are quite common among owners of all brands of notebooks. On average, laptop batteries last one to three years. Their exact lifespan depends on several factors, such as how much you use the batteries, the number of charge-discharge cycles and the quality of the batteries. Lithium-ion batteries begin to lose the ability to hold a charge over time. Before you replace a laptop battery, consider that there may be other reasons that the laptop is not working properly. You may be able to recharge the battery instead.
1.Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
2. Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
3. Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
4. Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5. Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.I hope you find it very helpful. Best regards.
Dec 05, 2012 | Lenovo Computers & Internet
Hp laptop dv4 2113tu charge light is blinking...
It could be adapter.take out the battery and plug in ac charger.if it switches on then it could be the main board is not charging the battery up.
Oct 27, 2012 | Computers & Internet
My Sony PEG-T615C/G works well but the battery will not hold a charge. Can I replace the battery? if so, what type is it?
Hello
Your system definitely uses a lithium ion battery.
Over their lifespans, lithium-ion batteries can lose the ability to hold a charge. After a few years, some batteries will last only a fraction of the rated runtime. Replacing a battery is relatively simple; most pop out from the bottom or back of the laptop.
Many retailers, however, charge hundreds of dollars for a new battery. Sites like batteries.com specialize in discount laptop batteries and can save you money on a brand new battery for your laptop. For example, a Dell Latitude D620 Li-ion battery costs $139 on Dell's Web site and $83.99 on batteries.com, as of press time. (The company even offers a two-year warranty and 45-day money-back guarantee on all laptop-battery orders.)
Aug 11, 2011 | Sony Computers & Internet
Hi. Our Advent Roma 2000 laptop seems to have a problem charging. Thought at first it was the charger so bought a new one, but still the same. The charging light flickers on and off as though there is a...
If you wiggle the connection to the laptop and it feels a bit loose, then the power connection on the laptop itself probably needs re-soldering. This is a common problem with laptops. Unfortunately unless you can do it yourself or know someone you can, then it will cost quite a bit to get fixed outside of warranty.
Feb 28, 2011 | Computers & Internet
The battery won't hold a charge. it's a brand new
Have you checked the pins (the points that the battery takes power from the laptop)? Try cleaning them with alcohol and check loose contact.
Try these and in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 08, 2010 | Acer Aspire 3000 Notebook
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
My laptop battery won't hold any charge
its the connectors to which the battery gets connected internally that r either loose or boken from internally needs replacement or a minute reparing.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
