Question about Konica Minolta DiMAGE Z6 Digital Camera
Camera goes on, red light, then goes off
When I turn on camera, it says "accessing files" and then the red light blinks and the camera goes off. I tried 2 new sets of batteries and that did not work and also tried leaving batteries out overnight, No change. thanks for your help!
  • 2 more comments
  • Susan Winters Jun 10, 2007
    this didn't solve my problem. the lens does extend.
  • Susan Winters Jun 14, 2007
    the secondry element does move.
    thanks
  • Susan Winters Jun 16, 2007
    Apparently the camera still takes photos. I just can't see anything in the display or in the photo review. I tried a few photos and then took the memory card out and put it in another device and there were photos there!
  • Susan Winters Jun 17, 2007
    So, how do I go about fixing that?
    thanks!
    Sergeant:
  • 279 Answers
Assuming this hasn't been fixed, as it is a bit old... You would have to open up the camera and short the connections to various buttons and switches to test them. If it is a button or switch, when you short that one it should start working again. It' sort of tricky to do, since you have to open it, but have it on so you can test it. Once you find the bad button or switch, it's just a matter of replacing that part.
Posted on Aug 31, 2007
    Novelist:
  • 107 Answers
If the lens does not extend then the problem is that the focus element inside the lens has gotten stuck. This is a common issue on this model of camera. If you are mechanically inclined you can remove the front lens cover and front optic giving you access to the secondary optic (this is the focus element). There is a tab of plastic which is easy to grasp with fine tipped pliers, simply grasp it and tug very gently. Turn the camera on and the element should begin moving normally again. If you are not able to do this, or do not have a fine tip screw driver and pliers you can take it to a camera repair shop and give them this information. They should be able to do the procedure for you for a small fee. If the lens does extend, then this is not the problem and I am unsure how to address your problem.
Posted on Jun 08, 2007
  • 1 more comment
  • David Millier
    David Millier Jun 10, 2007
    Yes, even if this is the case the outer lens will extend. When you turn on the camera look inside the lens, does the secondary element move? If it does not - then this is your problem.
  • David Millier
    David Millier Jun 16, 2007
    If both the outer lens and the inner lens move, then the problem is internal and probably involves a board or component failure. Konica-Minolta no longer exists, their assets were acquired by Sony last year. Getting any parts is hit and miss, we did just receive a replacement battery door for a Dimage Z2 - but this is the only part I have seen come from Sony for these Konica-Minolta cameras recently.
    You could send the camera to a repair facility like ours and get it looked at for $40, fixed for $60-$150 depending on the root cause of the problem. Or you could sell it "as-is" on ebay for $40-$60.
    Hope this helps!
  • David Millier
    David Millier Jun 17, 2007
    Congrats. You might be looking at some simple button or switch failure on the rear controls. Given that you see "accessing files" when the camera turns on, that shows that the screen is not dead.
When I turn on my olympus sp-500uz it often goes straight to card setup when i turn it on. I often lose the pictures that I have on the card because I have no choice but "POWER OFF" or "FORMAT" and when I...
I'm afraid you have a bad memory card. Would be better to buy a new one. see it as an extra. They are not that expensive today.
And if your camera tells you to format, first switch off the camera. Then remove the card and try to read the pictures to your computer first. There are programs can recover pictures, your camera can't show.
see these links if you don't already have recover software.
www.cardrecovery.com www.wondershare.net with free trail
www.cardrescue.com with free evaluation version
Take care you never remove the card before switching off the camera complete and wait till no light is on or blinking.
When you switch of the camera it could be it has to access the memory card, to write the last info it still had in its internal memory. they is when a light goes on or blinks. If you then remove the card or the battery, your file structure can be damaged very easy.
Most camera's show a light when the camera is accessing the memory.
Jan 18, 2014 | Olympus SP-500 UZ Digital Camera
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Apr 12, 2012 | Televison & Video
My rebel XTi won't connect to my mac.
I had the same problem but solved it with iphoto: after turning on the Mac, plug in the XTi and wait for a moment for iphoto to pick up the camera. Rest was an auto process.
May 17, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Is there any way to download the set-up disk for my jvc gz-hd7u
Connecting the Camera to the PC
Preparation:
Set the camera’s power/mode switch to OFF.
NOTES
• When the USB cable is connected, turning on or off the camera causes malfunctions of the PC.
• Connect the camera directly to the PC, not through the hub.
• Do not use an extension USB cable.
• Saving the wrong kinds of files in a recording medium or deleting files or folders from a recording medium can cause problems with the operation of the camera. When it is necessary to delete a file from a recording medium, delete it through the camera. Also, do not move or rename folders and files in the medium on PC.
• Never disconnect the USB cable while the access/charge lamp on the camera lights or blinks.
1 Create a folder to back up files into.
2 Set the camera’s power/mode switch to STANDBY/ON.
3 On the camera, move the set lever to
\/ / /\ to select [PLAYBACK ON PC],
then press down.
4 Double-click [EVERIO_HDD] or [EVERIO_SD].
5 Select the folder that you want to back up, and drag & drop it into the folder you created in step 1.
SD_VIDEO:
Folder that contains video files. If you want to back up fi les individually, open this folder, and drag & drop folders such as [PRG001] one by one.
DCIM:
Folder that contains still image fi les. If you want to back up fi les individually, open this folder, and drag & drop files such as [PIC_0001.JPG] one by one.
When you have finished operation
Always follow the procedures below when disconnecting the camera, or turning off the camera/computer power.
Failing to do so may cause damage to the camera and computer.
1) Confirm that the access/charge lamp on the camera does not light or blink. (If the access/charge lamp lights or blinks, wait until it is turned off before proceeding.)
2) Double-click the [Safely Remove Hardware] or [Unplug or Eject Hardware] icon in the status bar.
3) Select [USB Mass Storage Device] or
[USB Disk], and then click [Stop].
4) Click [OK].
5) Disconnect the USB cable.
6) Turn off the camera and PC.
Sep 20, 2009 | JVC Everio GZ-HD7 Camcorder
I try to turn on camera and first I get green light then red blin
i try to turn the camera...but it seems that hangup,,,,the lights green it blinks blinks,,,,and theres a circle on scren.....i have lotsof pic there that is very important for school...was it gone?waht can i do so that my pic wont lost?pls help..
Apr 10, 2009 | Cameras
After taking one photo, camera display blinks and can't turn off or take more pics
TIggertigger, allthough batteries have improved alot they still eventualy die, by the sounds of this proublem the battery has died for what ever reasen, try getting a new battery. If this does not help try a filmwere upgrade, for insturctions on how to do this please contact canon.
Jun 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Blinking red indicator light
Hey pollyannac,
The red blinking light probably means either the flash is recharging, or the camera buffer is full and it is writing files to your memory card which the lcd monitor should read Busy while the camera is writing the files. If it is the flash recharging then you could try using more powerful batteries such as the Canon NiMH AA batteries. If the problem ends up being the camera is writing images to the memory card you could try getting a memory card that has a high write speed. These memory card are usually more expensive, but in my opinion well worth it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot A720 IS Digital Camera
Green light goes off, red light comes on and camera goes off.
I have fuji, finepix s700. DIGITAL CAMERA
What happens when the light blinks red and green repeatedly every time I want to turn the camera on? I know that this camera also uses batteries. Does this mean I should replace them?
Jun 03, 2008 | Cameras
Konica Minolta DiMAGE Z6 Digital Camera Logo
49 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
