Question about Hyundai 2012 Tucson
Hyundai tucson starter remote problem
After I start the car with the remote, I can not unlock the doors by the remote. I have to opened the door with my key.
maklean
  • 1665 Answers
SOURCE: door handle
Door inside hande may is disengaged Remove door inside panel to inspect.
Posted on Jul 13, 2008
  • 53 Answers
SOURCE: Drivers Power door lock?
the most common fix for this is what is called the accuator that must be replace it is part of the latch assembely
Posted on Oct 19, 2008
SOURCE: 2003 Hyundai Sonata Door Lock Problem
I had this problem. Through some research and asking some service personnel I found out it is a fairly easy fix. You will need to buy a new relay switch for the door locks. The dealer will/should know what you need. They are located (two of them, buy two and replace both) on the back side of the fuse box. It is not that easy to get back there. I had to lay on my back with my head up under the instrument panel. They are visible and can be removed if you take some time and be careful. Once I knew what I was looking at, it was easy to replace and the remote works like a charm. You can go to an auto supply, like Autozone, and they should have a schematic to show you where these relays are.
Posted on Jun 03, 2009
ghost45
  • 1280 Answers
SOURCE: 2004 Hyundai Sonata door lock functions inoperable.
you have a bad relay.. the 'lock' relay.
Posted on Sep 23, 2009
cris_p
  • 62 Answers
SOURCE: cannot open fuel door with, driver side door remote actuator.
the fuse is probably bad
Posted on Feb 19, 2010
The drivers side cook lock does not lock or unlock using the remote. The other door do respond to the remote. What is the cause and solution?
Hi Charles
The drivers side door gets the most use
Check the actuator wiring coming through the door hinge
If it works from the key then the Power to the door is OK & the key switch is ok. Must be trigger wire from wireless device receiver!
Good Luck
Hyundai Door Lock Actuator eBay
Hyundai Entourage Alarms Remote Car Starters Keyless Entry Locks
Jul 08, 2015 | 2008 Hyundai Entourage
I replaced dead battery on 2005 Hyundai Tuscon and now car cranks over but will not start appears no fuel or no spark,car worked fine before battery died
immobliser problem ,,,,, or a crash switch has tripped ,,,,try turning on ign and disconnect and reconnect the battery,,, be careful to do it without making slow connections for fear of sparks and leave door open for fear it could lock up ,,,, u may have to lock and unlock using remote after,,, hope this helps
Dec 06, 2013 | 2005 Hyundai Tucson
2012 hyundai tucson setting the garage door opener that is located in rear view mirror
Thanks filter4991;
1. Press and hold button on car's rearview mirror
2. Press and hold button on garage door opener's remote control.
3. Light on Rearview mirror will flash rapidly.
4. Release both buttons.
5. Locate learning button on garage door opener (generally this can be found by tracing the antennae to where it is attached to the unit.)
6. Press and release "Learning button"
7. Press and release rearview mirror button repeatedly until garage door opens/closes but it should work the first or second time.
Worked on Genie Intellicode and Hyundai Tuscon
Sep 20, 2012 | Hyundai Tucson Cars & Trucks
The door locks work off and on with the remote. Have to use the key to open doors. After that, the car won't start after sitting overnight. Dead no turn over. Some days the locks work just fine with the...
Hi. Thanks for your question. You can perform some troubleshooting steps and see what is the exact issue for further assistance you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Feb 25, 2018 | Hyundai Tucson Cars & Trucks
I tried to open my tucson wit the key and the alarm was activated and the alarm keeps goin off and it wont let me start the car
Okay try locking the door with the key and then unlocking it, this should sut down the alarm if it doesnt then try the pass/side door lock with key, the switch on the drivers door lock may be bad, also i'm not sure if this is a factory alarm or not. hope this helps.
Oct 31, 2010 | 2008 Hyundai Tucson
2006 Hyundai Tucson Car - the battery is totally drained & dead so it wouldn't open with the remote opener. Now that we used the key when the car starts to get battery power back the alarm sounds...
this is for honda acura but it also might work for you too.
Open hood ensure new battery is disconnected.
Open main fuse panel cover under hood and remove horn relay (so you don't have to listen to the horn).
Use the key to lock the drivers door.
Connect the positive battery terminal.
Connect the negative battery terminal (security system will now activate, hazards lights will flash and horn would be going off if the relay was not removed).
Use the key to unlock the drivers door.
Get in, close drivers door.
Use the key to start the engine.
Security system will deactivate.
Get out of vehicle, reinstall horn relay, replace fuse panel cover, close hood.
Oct 15, 2017 | 2005 Hyundai Tucson
We have a 2007 Entourage and you cannot lock it with the car running. We installed a remote starter and it will not lock the doors when it is remotely started. Can this feature be disabled?
i think that this is to prevent you from locking your keys in the car with the engine running.
Some remote starters have a feature that when the car is running (and in park) you can hit the remote start button twice for one second each - then you can take the key out of the ignition and still have the car running.
At this point....if you would hit the 'lock' button on your door the doors would immediately unlock. However, if you get out of the car and close the door leaving it unlocked and then you hit the 'lock' on your original car remote the doors will lock and stay locked. So now the car is running the doors are locked and you have the keys in your hands. Then you can run into the store or house real quick with your car locked.
Once you come back, you hit 'unlock' on the original car remote. the doors will unlock - you can get it - and then before hitting the brake put the key in the ignition and turn it (dont crank it) as if you had when originally using the remote starter.
Maybe this will work for you.....
Oct 14, 2008 | 2007 Hyundai Entourage Limited Minivan
Hyundai 2012 Tucson Logo
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Steven Mitchell
Steven Mitchell
Andrew Taylor
Andrew Taylor
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
