Question about Linksys Wireless-G WRT54G Router
"unable to connect to selected network" error
I have an ancient Dell Latititude C600 that works great on all unsecured wireless networks i've ever tried it on but whenever i try to connect to my home wireless network i get a message that says, in full, "Windows is unable to connect to the selected network. The network may no longer be in range. Please refresh the list of available networks, and try to connect again."
 I'm pretty sure it's not a problem with my computer because it works on other nets. The only thing I know to do is shut everything down and restart. That was, of course, no help at all.
 The wireless router is a Linksys WRT54GS ver.6 and it works great on other laptops I've had. For some reason these two just aren't getting along ;)
 Any suggestions?
  • ambdukias66 Jan 12, 2009
    I'm not sure how old it is, it's a hand-me-down of sorts. The adapter is a PMCIA Cisco Aironet 350 series version 7.29.0.0
    Now my problem has increased. I went on to the MSN site to see if i could figure it out there. Their tutorial said to delete the wireless driver and reinstall it. I deleted it and now can't find anywhere to download the driver.
  • May 11, 2010
    How ancient is ancient? Does this laptop have integrated wireless or are you using a USB or PCMCIA adapter? Is your home network secured, and if so, are you using WPA? Some older adapters only supported WEP security.
  • 42 Answers
Hi, May be your router is now running a more secure algorith and needs password etc which the old one can't handle. You may have to downgrade your router to the older system..not a good idea.
Posted on Jan 10, 2009
My computer doesnt want it connect to internet,, appear the connection icon but when the page try to open , it cant do
Please follow the steps provided below:
Q: Basic Wireless Troubleshooting
A:
The following steps will help determine if the wireless card in the system is functioning properly.
IMPORTANT:
Please go through all the troubleshooting steps. If the wireless card is functioning properly, please check the network configuration. Acer America can not assist with configuring the network.
Before you start:
  • Make sure there is a wireless router or wireless access point.
  • The wireless router/access point is plugged in.
  • Refer to the owners manual to ensure the wireless adapter is on (you can turn the wireless card on and off by pressing a clear button)
  • Contact the internet service provider to make sure ther account is active and the network is connected in a way that supports their configuration.
If the computer was working properly at an earlier time:
If the laptop was working fine, do a System Restore which rolls the system back to the last known working configuration. System Restore is located in System Tools under Accessories. Here is a link to explain the use of this feature:
http://support.microsoft.com/default.aspx?scid=kb;en-us;306084
To find the wireless network:
1. Click on Start winxpstart%20button.jpg then click on "Control Panel."
xpmenu.jpg 2. In the Control Panel window, click on "Network and Internet Connections."
3. In the "Network and Internet Connections" window, click on "Network Connections."
networkconnect.jpg 4. Once in Network Connections, right-click on the wireless connection then select "View available wireless networks"
5. If the wireless network is a secured network, please refer to the manual of the wireless router to make it unsecured for the purpose of testing the wireless network.
NOTE: Acer does not recommend leaving a wireless network unsecured and is not responsible for data accessed due to unsecured wireless networks.
6. If the wireless network is listed, the wireless adapter is functioning properly. If unable to connect to the wireless router, go through "Before you start" at the beginning of this article.
Mar 05, 2011 | Acer Aspire 5100 Notebook
My laptop is connected to my unsecured wireless network via my linksys router, but my iPad and other laptop will not connect. I am getting an error message that says, "Unable to join the network...
I would try to set up the network with a new SSID due to settings being saved in some devices, and because someone else may have a linksys network set up that you may accidentally be connecting to.
After that, try basic security settings.
Also, make sure you don't have MAC address filtering enabled on the router. To check this, you will have to login to the admin area and look for MAC address filtering.
Nov 28, 2010 | Linksys Computers & Internet
I have an older dell desktop with a pentium4 and runs on XP. It has a Dell truemobile 1180 USB Adapter that connects to wireless networks. Everything worked fine at the last house with 2-4 out of...
In the Network Connections window, right click on the USB adapter and select Properties. Select the "Wireless Networks" tab. In the Preferred networks area, select the name of your wireless network so that it is highlighted. Then press the Remove button. Click OK.
Windows should now inform you that it has located an available network. Try connecting into it now.
Aug 24, 2010 | Dell Computers & Internet
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
Unable to connect to internet
if you give the wep key in the router or modem or the access point then you give the wep key in that if not there direct connect it and you can check also where its give the password or not just go to the right click on the wireless icon in the taskbar then go to the view available the network in that your wireless ssid shows just click it in that you show the lock symbol then your network in the password its wirten that unsecure networks then you direct connect it
Jan 12, 2009 | Dell TrueMobile 1180 802.11b Wireless...
''unable to connect to selected network'' error
If you can connect your laptop to other wireless and others can connect to your wireless but you cannot means that its on your laptop wireless network configuration.
If you have Windows XP, go to Start > Connect to > right click on your wireless connection and select "Properties". Choose the "Wireless Network" tab and under "Preferred networks" remove ALL wireless network, reboot your PC and then go here again and then re-Add your own wireless network only. After you Add highlight it and click "properties" button. Checked "Connect even if this network is not broadcasting and if you have put a security on your wireless to select the correct authentication type.
Then on "Connection" tab checked "Connect when this network is in range". On "Advanced" tab make sure to Uncheck "Automatically connect to non-preferred networks".
On Windows Vista delete all Preferred Networks under "Manage Wireless Networks",(under Network and Sharing Center on Control Panel). then turn off and on your pc. And then try to reconnect and make sure this time, PC will ask for network key. ( if you set it up that way )
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
TRYING TO CONNECT DELL LATITUDE C400 TO WIRELESS ROUTER ALL READY INSTALLED.
Connecting XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Jan 06, 2009 | Dell Latitude C400 Notebook
Wireless problems with windows vista
You just need to remove the preferred networks on your vista, follow this.
Right click the wireless icon>network and sharing center>manage wireless network>remove all preferred networks.click OK.
Then connect again to your network that should solve it.
Jun 13, 2008 | Linksys Wireless-G Broadband Router
DELL C600 Ethernet ports quit after installing mcpcia wireless
Try device manager and see if they are disabled. I've seen this happening a few times
Sep 29, 2007 | Dell Latitude D600 Notebook
Linksys Wireless-G WRT54G Router Logo
352 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
