Question about Cobra Radio Communications
Need powermike for a 142 gtl cobra 5 pin - Cobra Radio Communications
    Genius:
  • Cobra Master
  • 1,795 Answers
Www.copperelectronics.com and they will wire it for you.
Posted on Nov 25, 2014
Mechanic688
  • 204 Answers
SOURCE: B- kit
I think it would be better to buy an expo kit already built for your radio. There is other components on the board with the crystals and their values are very critical for tuning it exactly on frequency. Good luck with it,, Mechanic
Posted on Jan 14, 2008
Communicomm
  • 90 Answers
SOURCE: Cobra 142 GTL no dead key
Are you sure that you're on the AM mode? It sounds more like you're on LSB or USB. If you are on AM, the problem may be the power control (VR6) inside the radio.
Posted on Nov 12, 2008
audio20
  • 22 Answers
SOURCE: cobra 148 gtl dx manual
This is the Manual for the C148GTL
Posted on Apr 23, 2009
  • 773 Answers
SOURCE: Cobra 1000 GTL by Dynascan
This is a complicated modification. I have never done it to a 1000 GTL, but its done basically the same in all radio's.
I don't recommend doing it, especially since I am not 100% sure on how exactly to do it. I have never been in a 1000 gtl. If I had one in front of me I could tell you for sure how to do it.
If the reason for Variable power is a linear, just a swing kit in for the dead key you need, most likely 2 watts, and leave it.
Here is how to do a variable power mod. this is assuming the swing mod is done the same to this as a cobra 25/29 or uniden 68/76 etc.
If you would like to try it, here it is.
You get a TIP31 transistor, Radioshack has them.
Where you put the swing mod in the radio, which is a cap and a resistor, you put the TIP31 and cap. A 47uf cap works fine.
With the resistor facing you, and the tab in the back away, solder the cap to the transistor. the leg with the black stripe goes on the right most leg. then the other goes to the center leg of the transistor.
Solder a wire on the left most leg, long enough to reach the front of the radio. Now solder the 2 legs that don't have the wire on it, in the place where you would put the swing kit, with the black stripe on the cap facing the back of the radio usually.
Remove the wires from the RF gain and solder them together.
Now solder the wire from the transistor to the center tab.
Remove VR6 and solder a wire from the top tag of the RF gain to the top connection of VR6 that you removed.
Then connect a wire from the bottom tag to a ground point. The side of a tuning can works fine.
Take a piece of shrink tube and put it over the TIP31 so it does not ground against the heat sink, that would be bad.
This is done basically the same in all cb radio's.
Posted on May 03, 2009
Benimur
  • 6966 Answers
SOURCE: cobra 142 gtl no audio on receive
Hi and welcome to FixYa,
Initially, the speaker of course has been checked?
Offhand, would partial schematic of the mic and speaker section help?
Good luck and thank you for asking FixYa.
Posted on Dec 20, 2009
I am visually d and I have a D104m6b power mic I am tryinto a 5 pin Cobra 142 GTL
Recommend you contact your local authorized reseller/repair tech for assistance or online support here: Support Cobra Electronics Corporation
Sep 28, 2017 | Cobra Radio Communications
I have cobra ca61 desk mic i need it wired to my cobra 142 gtl home base. the base has 5 pins so i need my mic to be wired for 5 pin... any ideas?
cobra 5 pin to 4 pin adapter on ebay around $5.00
http://www.ebay.com/itm/WORKMAN-C4P5C-CB-RADIO-MICROPHONE-ADAPTER-5-Pin-COBRA-TO-4-Pin-COBRA-/121655850211?hash=item1c5340f4e3:g:e0AAAOxy2YtRsJ8n
Apr 10, 2015 | Cobra Radio Communications
I need wire 4 pin mic to a 5 pin mic cobra 142 Gtl?
you'll have to seperate the ground from the shield and then attach the rx,tx,and ground ,the shild then the ground thats on the shield.
Apr 30, 2014 | Connex Radio Communications
I need to wire a 4 pin to a 5 pin mic turner plus 3 to a cobra 142 GTl
pin#1 audio lead #2 audio shield #3 receive control #4 ground #5 transmit control
Apr 30, 2014 | Cobra Radio Communications
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
Problems with Cobra 142 GTL
the diode and missing resisters are and caps are probably the culprits.
Feb 01, 2012 | Cobra Radio Communications
Low dead key on my radio
If it is a 142 GTL your A.M. power is VR6 . Good luck and be carefull and DON'T get carried away remember AT YOUR OWN RISK NO LIFE GAURD ON DUTY!!!! You should'nt have any problems though......Dan
Apr 01, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
5 pin mic
All "older", "real" or "desirable" Cobra 148 GTLs came with side-mounted 5 pin microphone sockets. For wiring information, see...
http://www.offroaders.com/info/tech-corner/reading/mic-wiring.htm
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
43 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
