Question about Lasko Heating & Cooling
How do i prevent my lasko heater to keep raising the temperature? i can't seem to set it to stay on one!
    New Friend:
  • 12 Answers
If its a central heating unit you should make sure the batteries in the thermostat are good and the fan switch is on auto. then you can open the cover to the heater and tap on the relay. that will usually shut it off if its just sticking. It could be a black box by itself or a box on the circuit board depending on the model
Posted on Nov 29, 2012
5 Suggested Answers
farfield
  • 462 Answers
SOURCE: Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Posted on Mar 04, 2009
SOURCE: I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Posted on Nov 18, 2009
  • 120 Answers
SOURCE: The economy setting on my 25TR heater does not
The sensor for these is inside at the rear near the filter. Choices are really limited to just turn it on and off when you want heat or spend the money on getting it to an agent. If you have never had it serviced I would reccomend getting this done. Maybe whilst it's being cleaned out you can get some adice on got of part replacment. Likely to be either the sensor or the control board itself (ouch on the latter)
Posted on Jul 20, 2010
markfreedman
  • 312 Answers
SOURCE: My Lasko 5805 heater worked
Hi, I looked through the manual for the information to change the thermostat display from reading Celsius to Fahrenheit. Couldn't find anything. I did find a number to call for customer service
800-233-0268
Also, Here is the link to the manual.
http://www.laskoproducts.com/instructions/5800Ins5800ESa.pdf
Hope this Helps,
Happy New Year,
Mark
Posted on Jan 02, 2011
How do I regulate temp on my lasko heater
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Jan 05, 2014 | Lasko Ceramic Heater
Cant get the heat to go past 71
Check your thermostat. Maybe it's cutting off ahead of the set temperature. May need recalibration or replacement.
Nov 12, 2012 | Lasko 5620 Electric Baseboard Heater
I can't see the green temperature numbers anymore. Can that be fixed?
Not economically viable to repair, however the temperature is not what matters, comfort is, and if you set it midway and like that mark it and leave it where it works ok for you. Thermostats are not always jiving with thermometers .
Oct 31, 2012 | Lasko 758000 Ceramic Heater
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
Unit shuts itself off after a minute or two.
Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Mar 06, 2007 | Lasko 5365 Ceramic Compact Heater
Unit shuts itself off within a few minutes.
. Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
Heating & Cooling Logo
169 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
