Random beeping from Acer Aspire laptop (brand new only had it for 3 months)
The laptop keeps beeping randomly no matter what, I can't find a specific rythyme to when it beeps because the sounds occurs randomly and it doesn't matter if I have my laptop plugged in or not.
    New Friend:
  • 34 Answers
Go to authorise acer care center . ur laptop is in warrenty so they will fix it for free. do not try to repair of fix it by urself.it may end your warrenty.
Posted on Dec 01, 2012
stif_NEC
  • 441 Answers
SOURCE: Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Posted on Aug 16, 2008
leecom72
  • 4806 Answers
SOURCE: acer aspire 1 netbook won,t boot up.
Hi
When you first turn the machine on hit F2, that will take you into the bios menu, i don't know what version your machine is using, but the information is usually on the first page, you should find it easy enough because it will be next to the CD/DVD drive.
Posted on Feb 01, 2009
leecom72
  • 4806 Answers
SOURCE: Laptop makes horrible beep sound when plugging in power cord!
Many laptops do this and there is nothing wrong but it can be annoying and in most cases nothing can be done about it apart from going into the BIOS and seeing if you can disable it.
Regards.
Posted on Aug 18, 2009
Testimonial: "Thanks for the quick response!"
will-raven
  • 83 Answers
SOURCE: Screen problems on Acer Aspire 5740
I don't know that it is a common fault with this specific model, but laptops in general have this issue mostly due to a dying LCD power inverter. It is typicaly located at the bottom of the LCD screen and costs between $30 - $75 dollars for the part, and usually $75-$150 for someone to replace. If you like the laptop it is usually worth it to have replaced. You can also hook up a monitor to the VGA port on the laptop and then go into your display control panel and enable 2nd monitor to use it instead of your laptop lcd.
Posted on Apr 30, 2010
FingerStrong
  • 190 Answers
SOURCE: Acer Laptop Aspire 5315 Continuous Beep on Start Up
its either there is a stucked key on your keyboard or you have a bad ram (memory card).
Posted on Jun 11, 2010
Random continuous beeping from Acer Aspire and i bought it in September so it is a brand new computer and it does this either way is plugged in or not and it happens randomly
Mine beeps if the charger isn't plugged in completely or connecting completely. It does it persistently if not connected completely and I tap the keyboard (slightest movement) good luck.
Nov 29, 2012 | Acer Aspire 5100 Notebook
I didnt use my laptop Acer Aspire 5517 for like 2weeks, when i had to turn it on it started with a continuous beep while loading BIOs. then stops at final start up.
Hello, From the problem you have stated, once there is a continous beep on a system or laptop, majorly it is a RAM problem, RAM means random access memory.Since you said it is making that noise, you can remove the RAM, clean it pins and re-insert it properly into its slot,if the problem persist then you need to get a new RAM,not just anyone,the one that is supported by your laptop. Regards
Dec 09, 2010 | Acer Aspire 7520-5185 Laptop
I have an acer aspire 2930 that randomly types letters of its choice zdvn very popular even when you are not typing it aslo flashes up bluetooth not connected and other strange things?
Hi I had the same problem, i had to use a usb keyboard for a while, i updated my drivers but ended up removing then reconnecting the keyboard and so far haven't had any random "Ghost" typing & the Bluetooth has stopped turning on and off. Found this helpfull: http://tim.id.au/laptops/acer/aspire%202930.pdf
Hope it works!
May 11, 2010 | Acer Aspire 2930-4661 Notebook
Acer aspire 5630 laptop keeps shutting down
It sounds like someone has suggested that overheating may have caused the random shutdowns (which is quite plausible). There are a few tools that can diagnose what is happening:
  • Temperature: I use SpeedFan (http://www.filehippo.com/download_speedfan/) to discover the temperature of my cpu. My Acer 5630 is usually doing 50 to 60 degrees. Anything higher than that could cause the random shutdowns (I've seen it happen on other laptops). If you download this program, don't muck around with the settings (as it would advise you not to anyway), just look at the temperature readings (eg. core 1 core 2)
  • I keep a cpu usage meter on my sidebar (http://gallery.live.com/liveItemDetail.aspx?li=587ef54f-e121-418b-b258-e583e105a0d6). It keeps an eye on the CPU usage so if i see it say 100% cpu usage then I suspect some software is inappropriately consuming resources.
Treatment of overheating would be to find the offending software and manage it or remove it. If it is not software at fault, then it may be that there is too much dust covering the ventilation (Your acer may be old and you may hear your fan increasing speed and the performance struggle sometimes). I opened up my one and found dust build up from the radiator all the way to the fan! (it was like around 1cm thick in some places, i wish i took a picture)
Another reason for random shutdowns is the integrity of the power switch or the lid sensor. My computer got rained on once and randomly shut down. It took a while of cleaning it with Circuit board cleaner from Repco (I had to open the panel that covered the power button and spray it). It got better everytime I cleaned it and now it reliably stays on (actually it randomly turns on now haha)
Jan 02, 2010 | Acer Aspire 5630 Notebook
Bluetooth activates by itself, random letters appears when typing
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
Jun 12, 2009 | Acer Aspire 2930-4661 Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
