Question about HP LaserJet 4300 Printer
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
  • HP Master
  • 1,684 Answers
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Posted on Feb 15, 2013
  • 24 Answers
SOURCE: can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Posted on Sep 25, 2007
byteguy
  • 2229 Answers
SOURCE: New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Posted on Feb 24, 2009
  • 87 Answers
SOURCE: The printer prints very slowly all of a sudden. It
Your print resolution may be set too high. Are you printing out simple MS Word files or websites or photos? Something with graphics will always take longer to print. To adjust your print resolution settings: Click Start, then place your cursor over "Settings" and then click on "Printers and Faxes". Find your printer in the list and RIGHT click on it. Select "properties". Next, click on the "printing preferences" button, then on the tab that says "Paper/quality". Click "Advanced". In the window that opens, click on "Print Quality" and select the lowest option (usually 300 dpi). If you need better quality, you can come back in and increase the resolution in the same way.
Posted on Jun 11, 2009
don_farr
  • 1018 Answers
SOURCE: HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Posted on Dec 14, 2009
Testimonial: "Thank you for your response, Even after I asked if every cord was plugged, I did'nt check myself. The usb cable was unplugged ! Agh !!!!!"
  • 164 Answers
SOURCE: Will not print periodically. Cannot clear print
Try downloading the latest driver from HP: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3435671&lang=en&
Often times the drivers on the CD are already out of date.
Hope this helps! If so, please give a rating!
Posted on Mar 09, 2010
Whne i click print nothing happens
You may have a print job stuck in your print que which is blocking any other print jobs from going through. Here is a step by step guide to clear the print que and see if that fixes your printing issue.
Apr 18, 2013 | HP LaserJet 2420 Printer
HP Officejet 5610v: Sent document to print. Somehow the settings were set to print offline, so nothing came out. I "unchecked" the "print offline" option. I tried to...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Feb 21, 2011 | HP Officejet 5610v All-In-One InkJet...
Printer will not print. Ink is fine, paper loaded,press print,....nothing happens. What can I do? I have had the HP Check what they could. All was OK except the items I tried to print were in what they...
Click Start
Click Control Panel
Click Printers
Double-click the icon for your HP printer, to view the "queue" of files to be printed.l
Right-mouse click the icon for your HP printer, and click "use online" (if "offline" currently is "checked").
Dec 20, 2010 | HP Office Equipment & Supplies
Out of paper clears print que
we need to restart the print spoolers to fix this,
click on start> Run> Type in services.msc. A window will appear with the list of services, there u will find Printer Spooler> Do a Right click on that and Restart it. Do the same thing 2-3 times and then give the command to print multiple documents, to check if the problem is fixed or not. Please let me know the same.
Aug 05, 2009 | HP Photosmart C7280 Laser Printer
I click print but nothing happens.
Try just copying something on the machine. Does it print? If so, its a computer problem try setting up your prunter software again
Apr 23, 2009 | Brother MFC 420CN All-In-One InkJet...
Hp psc 2110 all in one
Try to clear out all old print jobs and then go to your printer,
Right click on printer Icon and check to make sure it is set as Default.
Nov 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
I am using a HP Laserjet 4 plus. I got a flashing "PC" and "Load A4" on the screen and could not print. Pleas help.
Clear the Print Que in the PC, turn off and unplug the machine, turn it back on.. send a test print from the driver.
A4 is european paper size, your printer is set for letter, someone attmepted to print an A4 file. Which is in the page set up in what ever file was to be printed.
Next Time Please be specific?
Sep 11, 2008 | HP LaserJet 4 plus Printer
My printer will not print
I have a similar probelm. Have a HP lap top and an HPC6180 printer. Every time you shut the system down and then restart all of the files you wish to print end up in que and csn not get them out to print. No one seems to be able to understand how to get them out of que and printing.
Dec 29, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
HP LaserJet 4300 Printer Logo
480 people viewed this question
Seeker5211
Seeker5211
