Question about Car Audio & Video
I have a alpine fm stereo modulator 1220, is the control(purple) wire go to the power ant on the stereo?
4 Suggested Answers
  • 11 Answers
SOURCE: ipod control?
You can purchase the KCA-420i and connect it to to the ai-net port behind the headunit. This will allow you to send signal from your ipod to your alpine headunit while still retaining your operating functions to the ipod. Can be purchased for about 10 bucks on ebay.
Posted on May 21, 2009
Obertelli
  • 3006 Answers
SOURCE: AM FM CD DET FACE CAR STEREO: installed an alpine stereo in my mustang and every...
That's because the memory wire has not been connected to a permanent live supply.
There will be an ignition switched 12v supply and a memory wire. The first is yellow on many brands and the second is red, but you need to refer to your fitting manual to check or look directly at the wiring harness as the wires are often individually labelled.
Since they both take 12v some folks mistakenly think that they can just be piggy-backed to each other and feed from the same supply. They can, but only if it's to a permanent live feed but that then leaves the risk of the unit being left switched on when the car is parked and draining the battery.
Posted on May 07, 2010
gobindagogoi
  • 133 Answers
SOURCE: My alpine car stereo plays cd's, auxilliary but the AM & FM radio got audio sounds for 5 - 10 minutes. After that it does not work anymore. What's the trouble?
Its trouble is in inside
Posted on Oct 09, 2012
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
Hooking up a kenwood mp235
Blue/White - Power Control/Motor Antenna Control Wire
Brown - TEL Mute Wire
Blue - ANT. Cont. (Not Used)
White/Black - Front Left Speaker -
White - Front Left Speaker +
Gray/Black - Front Right Speaker -
Gray - Front Right Speaker +
Green/Black - Rear Left Speaker -
Green - Rear Left Speaker +
Purple/Black - Rear Right Speaker -
Purple - Rear Right Speaker +
Red - Ignition Wire (Switched +)
Yellow - Battery Wire (Continuous +)
Black - Ground Wire -
Here is a copy of the User Manual:
http://www.masterspas.com/manuals_av/Kenwood_KDC-MP2035.pdf
Jul 22, 2010 | Kenwood KDC-MP235 CD Player
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
How do i plug a alpine cd disk changer in to a poineer deck
honestly you most likely can not unless you purchase the fm modualator allowing you to hook it threw your antena and you wont be able to control it threw you deck (head unit)
Sep 26, 2009 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Alpine cva-1004 no audio video ok
Many aftermarket car stereo has to output trigger wires, one antenna and one amplifier. Antenna trigger only works in radio mode for the power antenna to operate. Amplifier wire operates in any mode the stereo is in. Check to make sure you hooked up the correct blue wire to your amplifer.
Bob
Nov 13, 2008 | Car Audio & Video
I need to connect an Alpine Stereo to a 12v battery in a boat. I know that that is not recommended but we got it used. I am not sure which wires to connect to where. Could you please help me?
Connect the yellow wire directly to the battery (this is constant 12v power, to maintain memory settings). Red wire gets wired to the switched 12v system (so that the stereo turns on and off with the ignition). Blue wire (or blue/white) would be for an antenna or an amplifier (if not used, just seal it off with electrical tape). Orange wire isn't used (that's a dimmer wire for tapping into a car's dash light dimming). Black is ground. The rest of the colored pairs (gray, gray/black, green, green/black, white, white/black, purple, purple/black) are the speaker outputs. The wires with the black stripes are the negative wires in each pair. They usually say on them which color corresponds to which speaker location (front left, rear right, etc). If not, take a look on the Alpine unit - sometimes there's a decal or diagram on there, or a list, which will tell you which wires to connect to which speakers.
Sep 26, 2008 | Alpine Car Audio & Video
Wireing diagram for a alpine cda-7892
Good Day,
Red is ignition
Yellow is constant hot
Black is ground
Gray wires are front right
White wires are front left
Green wires are rear right
Purple wires are rear left
Blue is power Ant if equipped
Orange is ilumm
Make sure you use the proper wiring harness for your vechile.
Hope this helps
Jul 06, 2008 | Alpine Car Audio & Video
I dont have a colour code for the wiring
Red is ignition
Black is ground
Orange is ilumm
Hope this helps
Jul 06, 2008 | Alpine CDA-9807 CD Player
Looking for wiring diagram for pioneer car stereo model KE-5757
Red is ignition
Black is ground
Orange is ilumm
Jun 23, 2008 | Car Audio & Video
Cd changer
You can use any CD changer that has an FM modulater. You would listen to it by tuning in to a station on your tuner.
The sales person at any place that sells car stereos would be able to show you the right type of changer.
If your radio has a cd changer controller built into it, you need to check with the dealership to find out what the OEM changer would be. But a FM modulator will work with any car stereo.
Kenwood, Pioneer, JVC, Clarion, Alpine all sell FM modulator CD changers. I would not personally buy any of the cheaper no name brands. The money you save on the cost is not worth the difference in quality. Panasonic is a very good brand for car stereos but not home stereos, but I don't know if they make CD changers. if they do, that would be a good brand.
Jun 15, 2008 | Car Audio & Video
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
