Question about Rival CZF530 Deep Fryer
Unit does not work
We used the unit once. The unit will not work. The power and
power cord are O.K.
  • tzinis Jan 17, 2009
    In electronics it is called infant mortality, characteristic of low quality.
    If one measures the resistance between the two prongs at the bottom of the control panel (after disconnected) it would read OPEN with the timer in the ON position. In a good unit it should read a nominal value
Let me buy your power cord on paypal if u cant fix it! please thanks
Posted on Jan 13, 2009
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
I have a laserjet m3035 no display on screen 2 LED light not work
Shut down the printer and remove the power cord. Leave the unit off for a minute or two. Replace the power cord.
  • 2 Press the "Power" button on the printer. Hold down the "Select" button on the printer as you turn the unit on. Continue holding the "Select" button until the LED lights on the printer flash once and then remain on.
  • 3 Use the up arrow to scroll to "New Maintenance Kit." Press the "Select" button to reset the maintenance kit counter.
  • Oct 20, 2011 | HP LaserJet M3035 MFP Printer
    My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
    Ok here's what you will do
    1) Unplug the notebook from the ac adapter (charger power cord)
    2) Take off the battery pack on the notebook
    3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
    4) After 15 seconds, let go of the power button
    5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
    6) Now press the power button once.
    7) If the unit boots, the unit suffered a slight surge
    8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
    I hope this helps and let me know how it goes afterwards
    May 03, 2010 | Tablets & eReaders
    My toshiba satellite L300 has no power
    Please follow these steps VERY CAREFULLY:
    May 03, 2010 | Toshiba Satellite Pro L300 Notebook
    When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
    Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
    Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
    Philips 765 CDR - twin deck
    Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
    Jun 03, 2009 | Philips CDR600 CD Recorder
    Kenmore Elite HE3 Dryer PF on control panel,
    HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
    I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
    Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
    Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
    Window unit will not power up
    You need to check for voltage to the display. Just knowing the plug is working doesn't tell you that the electronics are getting power. It is possible that the power cord is bad. Once you have tested the unit and the unit is actually getting power to the display, then it's probably the control board in this unit.
    Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
    Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
    You need to register the unit it will work:
    1.
    Make sure the Base Unit is switched on and has a Green light showing.
    2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
    3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
    4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
    the Deregistering an Extension Unit box below then try to register the Extension Unit again.
    5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
    (This cord is used to do the actual registering).
    6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
    7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
    (You can unplug the Extension Unit – it will remember being registered).
    8. Plug in everything that used to be connected to the Base Unit sockets.
    9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
    Apr 27, 2008 | Lands Phones
    Rival CZF530 Deep Fryer Logo
    Top Rival Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Ed Mac
    Ric Shull
    Ric Shull
    Level 1 Expert
    Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
