Question about Boss Rc 50
I turned on my RC-50 and Data Damaged came on, I checked the manual and executed factory reset, it the came up with Data Error, what can I do?
3 Suggested Answers
  • 51 Answers
SOURCE: I was trying to transfer
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Posted on Apr 06, 2011
  • 1137 Answers
SOURCE: cannot get my RC 50 to factory reset.
Here is the latest update:http://www.bossus.com/gear/productdetails.php?ProductId=772# Click on download. Their support number is 323-890-3743. Hope this helps.
Posted on Aug 28, 2009
How do you do a factory reset on roland xp80
Press UTILITY, press F6 (MENU) twice to select Factory, then ENTER. Press F6 (EXECUTE). Use the dial to turn Memory Protect OFF if necessary, press ENTER, then press F6 (EXECUTE)
Guide: https://www.rolandus.com/assets/press_media_resources/Factory_Reset.pdf
May 02, 2014 | Roland FANTOMG8
Factory reset on korg x 50
FACTORY RESET:
  1. Press the [GLOBAL] button to enter Global mode.
  2. Press the [EXIT] button.
  3. Press the [UTILITY] button
  4. Select "Load Preload Data," by using the ClickPoint [?] button, and press the [CENTER].
  5. Choose "Kind," (All)
  6. Press the [MENU/OK] button.
  7. When a dialog box will ask you, press the [MENU/OK] button
May 01, 2014 | Korg X50 X-50 Keyboard
Memory full
Try doing a factory reset by following the instructions in the manual. It's the quickest and easiest way to "clean the slate" and only requires a few simple steps.
Jan 06, 2014 | Boss Rc 50
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 | Boss Rc 50
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
My suggestion:
Hope this helps
Apr 05, 2011 | Boss Rc 50
My Boss RC-50 has stopped working. I used the power chord for my RC 50 in my Boss OC 3 pedal and then tried using the chord in my RC 50 again and it won't work. It won't even work with other power...
CHeck the voltage out of the adapter. It should be around 9 to 11 volts. If it is not, it is possible that the OC3 has reversed polarity AND a protector that put a short on an incorrect supply. If so, it could have damaged the RC50 adapter. If the RC50 adapter is putting out correct voltage, then I suspect the inout connector on the RC50 may be damaged or not quite seated. Visually inspect the connector first.
Dec 04, 2010 | Boss Rc 50
I cleared one folder called WAVE with my computer and now there´s a messege on screen "data damage". the folder contains the preseted sounds inside. i need help.
Here's a hunch:
When the RC-50 was hooked up, your computer had access to the internal memory. The WAVE directory is where the wave data is stored. The RC-50 must have noticed that the wave data for patches that were supposed to have data was in fact gone.
So, you can probably just do a factory reset:
With the power off, while holding both single/multi and loop-sync, power the RC-50 up until it greets you with SYSTEM/PATCH use the PARAMETER buttons to go back and forth. In your case, you can probably leave "SYSTEM" alone and just select PATCH. Once you've selected which section of the RC-50 you want to reset, hit the WRITE button.
Aug 13, 2010 | Boss Rc 50
Cannot get my RC 50 to factory reset.
Aug 27, 2009 | Boss Rc 50
Boss Rc 50 Logo
239 people viewed this question
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
