Question about Philips Samsung Hl-s5086wx Hls5086wx Lamp With Housing Bp96-01472a
HLS5086 keeps turning off
The set starts up and quits after 30 seconds, bulb is replaced. jumpered the temp sensor, check the switch on the access panel and it is closed as well
  • Scott Nov 29, 2012
    It was suggested to me that there are some defective capacitors on one of the PCB but this was second hand.
    Top Expert:
  • Philips Master
  • 14,553 Answers
I would first suspect the ballast this model uses to power the lamp.
Posted on Dec 22, 2012
Water temp gauge works for about 30 seconds and then drops to zero
Most likely have a bad DIM. You may start to see the SRS light start coming on and the speedometer may stop working.
Nov 29, 2015 | 2002 Volvo S60
No power after 4000 rpms
This sounds like a fuel pump or fuel filter problem.
The 1988 Jetta has two fuel pumps. The "main" one under the car directly in front of the gas tank on the right hand side. The other fuel pum is in the tank. You can access that fuel pum by removing the round access panel in the trunk towards the back seat.
You'll need a fuel pressure gauge. You can usually borrow one from a large auto parts chain store.
FUEL DELIVERY & SYSTEM PRESSURES
System Pressure
Connect Pressure Gauge (VW 1318) between line from fuel distributor to cold start valve and
test port connection on lower chamber of fuel distributor, using Adapter Fittings (VW 1318/5).
Test port is sealed by a threaded plug. Bridge fuel pump relay with Jumper Switch (US 4480/3).
1.
Disconnect wiring from Differential Pressure Regulator (DPR). Open valve on pressure gauge
(points at cold start valve line when open) and activate fuel pump. System pressure must be 75-
82 psi (5.3-5.8 kg/cm2 ). If pressure reading is low and fuel pump delivery quantity is good,
replace pressure regulator.
2.
If pressure reading is high, disconnect fuel tank return line from DPR. Repeat test. If reading is
correct, check for plugged return line. If reading is incorrect with line open, replace DPR.
3.
Differential Control Pressure
Close valve on pressure gauge. Activate fuel pump with jumper switch. Leave DPR
disconnected. DPR reading should be 2.9-7.0 psi (.2-.5 kg/cm2 ) less than system pressure. If
pressure is incorrect, disconnect lower chamber return line and measure volume.
1.
Close open port to diaphragm pressure regulator. Activate fuel pump with jumper switch. Fuel
volume should be .14-.16 qts. (.13-.15L) for period of one minute. If volume is correct, replace
DPR. If volume is incorrect, replace fuel distributor.
2.
Close valve on pressure gauge. Install Test Harness (1315A/1) between DPR and vehicle
harness. Set multimeter to DCA 200 mA scale. Connect multimeter to test harness. Disconnect
wiring to coolant temperature sensor. Connect 15 k/ohm side of Test Resistor (VW 1490) to
sensor wiring.
3.
Turn on ignition and fuel pump. Differential pressure should be 10-17.5 psi (.7-1.2 kg/cm2 )
less than system pressure. DPR current should be 50-80 mA. If pressure is incorrect and current
is correct, replace DPR.
4.
If both pressure and current readings are incorrect, remove test harness from DPR. Ensure
resistance of DPR is 17.5-21.5 ohms. If reading is incorrect, replace DPR.
5.
If reading is correct, check ground from temperature sensor to cold start valve. If ground is
good, check power supply fuse. If fuse is okay, check terminals on ECU connector. If connector
is okay, replace ECU.
6.
Residual Pressure & Internal Leak Testing
Open valve on pressure gauge. Operate fuel pump for 30 seconds. Pressure can drop to a
minimum of 38 psi (2.7 kg/cm2 ) after 10 minutes. If pressure drops below specification, inspect
fuel pump check valve and all fuel fittings for leakage.
1.
NOTE: Pressure and leak testing does not include checking cold start
valve.
FUEL INJECTION SYSTEM - BOSCH CIS-E -1988 Volkswagen Jetta Page 1 of 3
http://www.ondemand5.com/mric/common/asp/printart.aspx 11/25/2011
If there are no leaks, check airflow sensor plate clearance. If plate clearance is correct, replace
diaphragm pressure regulator and repeat leak test. If pressure drop is not within specification,
replace fuel distributor "O" rings.
2.
Transfer Pump Delivery Volume
Check voltage supply to pumps. Connect Jumper Switch (US 4480/3) in place of fuel pump
relay, on relay panel. Remove fuel filler cap. Disconnect and plug off Black fuel line from
sending unit.
1.
Connect hose to sender port and place in measuring container. Turn on fuel pumps. Minimum
transfer pump delivery volume should be .42 qts. (.4L) in 10 seconds. Reconnect fuel line to
sender.
2.
Main Pump Delivery Volume
Check transfer pump (if equipped) and fuel filter. Disconnect fuel return line and place in
measuring container. Switch on fuel pump with jumper switch. Check fuel pump delivery
volume for 30 second period. Delivery rates are given with voltage reading at pump as volume
will change with different voltages.
1.
Minimum delivery volume for Fox, Quantum and Quantum Syncro models is .71 qts. (.68L) for
30 seconds with reading of 11.4 volts at fuel pump. Minimum delivery volume for other models
is .62 qts. (.59L) with 11.4 volts at fuel pump.
2.
Fuel Distributor
Check sensor plate adjusting lever and fuel distributor control piston for smooth operation.
Disconnect fuel injector lines at fuel injectors.
1.
Remove fuel pump relay and bridge fuel pump circuit. Use Jumper Switch (US 4480/3) in place
of fuel pump relay. When pressure has built up, turn off fuel pump. Move sensor plate from rest
position to end of travel.
2.
Uniform resistance should be felt during entire movement. No resistance should be felt on
quick return to rest position. Connect injector lines. Install fuel pump relay.
3.
Injector Quantity Comparison
Remove fuel pump relay, from relay panel, and install Jumper Switch (US 4480/3) in off
position in place of relay. Attach Fuel Quantity Analyzer (US 4480) to bumper and secure in
place. Remove injectors from cylinder head with fuel lines attached. Check and replace fuel
injector "O" rings as necessary.
1.
Check tightness of injector insert (2-piece inserts). If inserts are loose, remove and clean
threads. Use sealing compound when installing upper insert. Replace sealing washer that goes
against cylinder head below lower portion of insert. Lubricate injector "O" rings with gasoline
and install injectors, with fuel lines connected, into fuel quantity analyzer tubes.
2.
Ensure lines are not kinked or bent. Loosen fittings to align fuel lines and retighten. Remove
rubber boot from airflow sensor housing above sensor plate. Turn and lift setting screw and
adjusting slide of Sensor Plate Adjustable Holder (VW 1348/1) into upper position. This
simulates full throttle operation. See Fig. 11 .
3.
FUEL INJECTION SYSTEM - BOSCH CIS-E -1988 Volkswagen Jetta Page 2 of 3
Fig. 11: Sensor Plate Adjustable Holder (VW 1348/1)
Courtesy of AUDI OF AMERICA, INC.
Place sensor plate adjustable holder on airflow sensor housing with holder centered over plate.
Pointer on edge of holder base must point toward center of fuel distributor. Push adjusting slide
of holder down onto stop.
4.
Turn adjusting screw clockwise until magnetic end touches sensor plate retaining bolt. Activate
fuel pump with jumper switch. Turn adjusting screw of holder counterclockwise until any one
injector starts to deliver fuel. Turn off jumper switch and empty fuel quantity analyzer after
taking sample.
5.
Idle injection quantity is measured first. Lifting adjusting slide of holder to first stop simulates
idle position of sensor plate. Activate fuel pump until fuel level reaches 20 ml on scale of any
tube.
6.
Check that all injectors have identical spray patterns that are even and cone-shaped. If not, raise
sensor plate up quickly to full lift position and release. Repeat idle quantity test. Compare
amounts of fuel delivered by all injectors with analyzer held level. Maximum difference in
delivery quantity between injectors is 3.0 ml of fuel.
7.
If fuel delivery quantity differs between high and low levels by more than 3.0 ml, interchange
injectors and repeat test. If difference of delivery quantity changes with injectors, replace
injectors. If difference of delivery quantity does not change with movement of injectors, either
fuel lines are pinched or fuel distributor is defective.
8.
Measure full throttle injection quantity. Empty analyzer into fuel tank and reinstall injectors in
analyzer. Lift adjusting slide of holder to last stop to simulate full throttle position of sensor
plate. Activate fuel pump with jumper switch until fuel level reaches 80 ml on scale of any tube
of analyzer.
9.
sensor plate up quickly to full lift position and release. Repeat full throttle quantity test.
Compare amounts of fuel delivered by all injectors with analyzer held level. Maximum
difference in delivery quantity between injectors is 8.0 ml of fuel.
10.
If fuel delivery quantity differs between high and low levels by more than 8.0 ml, interchange
11.
Check fuel injectors for leakage immediately after delivery quantity test is complete. Set sensor
plate in rest position. Activate fuel pump with jumper switch for 2 minutes. Injectors should not
drip. Replace injectors that drip.
See image. Fuel filter is probably located on the frame between the engine and fuel tank.
Jul 03, 2012 | 1988 Volkswagen Jetta
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
2004 Honda 750 Aero. When you turn on the key, the temp warning light is suppost to come on and when you start the engine it goes out. Temp light comes on when over heat condition exists. The switch is...
Hi, Wildrider666 try hooking up an external jumper wire from the metal part of the temperature sensor to the negative side of the battery this is a simple circuit and should not be that difficult to diagnose if necessary run an external jumper wire from the sensor to the bulb reproduce the entire circuit if you must to eliminate faulty wiring. Good luck and have a wonderful day.
Mar 14, 2017 | 2004 Honda VT 750 Shadow Aero
2000 road king code 16 bike starts but won't stay running. not quite sure how to pull codes but it seems like I have a code 16(or I put it there during testing). crtank and cam sensors seem ok. resistance...
Code 16 indicates that the ECM has seen a battery voltage of less than 6.2 vdc or higher than 15.5 vdc. The most common cause of this is loose or dirty battery cables or shorted rectifier.
To access codes, turn the ignition switch on for about 3 seconds (one second after the fuel pump stops running) then turn the ignition switch off for three seconds. Repeat the above procedure. Then turn the ignition switch on again and about 8 seconds later the codes will start to flash through the check engine light.
If there are no codes present or there is a code and it does not appear again the code will clear its self in 50 start/run cycles. (Start/run cycle is defined as engine running for at least 30 seconds and off for at least 10 seconds.)
Oct 11, 2009 | 2000 Harley Davidson FLHRCI Road King...
My samsung dlp tv model#hln617w keeps turning off. Only stays on for 2 minutes. I replaced fan #2. Thunking that was the problem.
Why did you replace the fan was it noisey and did that cure the noise. These sets commonly have problems with color wheels-do you get motor noise at startup?
Sep 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Philips Samsung Hl-s5086wx Hls5086wx Lamp With Housing Bp96-01472a Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
