Question about Acer Aspire 5100 Notebook
Random continuous beeping from Acer Aspire and i bought it in September so it is a brand new computer and it does this either way is plugged in or not and it happens randomly
Mine beeps if the charger isn't plugged in completely or connecting completely. It does it persistently if not connected completely and I tap the keyboard (slightest movement) good luck.
Posted on May 03, 2013
SOURCE: Acer Aspire 3004 - Random reboots; random mouse program select w/o mouse click
Hi , I ask about how to download drivers for my laptop .. specification of my laptop is Aspire 3004WLCi
appreciate
Posted on Mar 27, 2008
  • 60 Answers
SOURCE: Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Posted on Sep 19, 2009
SpideRaY
  • 687 Answers
SOURCE: my acer aspire 5735 randomly shutting down
Try taking out your battery it might be shorting out just run your laptop from the adapter and see how long it lasts before it shuts down
Posted on Feb 22, 2010
SOURCE: bluetooth activates by itself, random letters appears when typing
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
Posted on Mar 14, 2010
will-raven
  • 83 Answers
SOURCE: Screen problems on Acer Aspire 5740
I don't know that it is a common fault with this specific model, but laptops in general have this issue mostly due to a dying LCD power inverter. It is typicaly located at the bottom of the LCD screen and costs between $30 - $75 dollars for the part, and usually $75-$150 for someone to replace. If you like the laptop it is usually worth it to have replaced. You can also hook up a monitor to the VGA port on the laptop and then go into your display control panel and enable 2nd monitor to use it instead of your laptop lcd.
Posted on Apr 30, 2010
Computer won't start at all - continuous long beeps
One long beep probably indicates that the memory chip(s) are not inserted properly.
Jan 19, 2014 | Acer Aspire E700 PC Desktop
Random beeping from Acer Aspire laptop (brand new only had it for 3 months)
go to authorise acer care center . ur laptop is in warrenty so they will fix it for free. do not try to repair of fix it by urself.it may end your warrenty.
Nov 29, 2012 | Computers & Internet
Acer am3470g turns off unexpectantly
Bring it back where you bought it. My first idea is an overheating problem from power supply or CPU.
Jul 26, 2012 | Computers & Internet
I didnt use my laptop Acer Aspire 5517 for like 2weeks, when i had to turn it on it started with a continuous beep while loading BIOs. then stops at final start up.
Hello, From the problem you have stated, once there is a continous beep on a system or laptop, majorly it is a RAM problem, RAM means random access memory.Since you said it is making that noise, you can remove the RAM, clean it pins and re-insert it properly into its slot,if the problem persist then you need to get a new RAM,not just anyone,the one that is supported by your laptop. Regards
Dec 09, 2010 | Acer Aspire 7520-5185 Laptop
Hearing continuous beep sound at startup that disappears on Esc
I started having the smae problem yesterday with my Acer 1410 bought end of 2009. It started after I had stoped some suspicious process to work on start up (using msconfig). During the night I scanned the computer for virus but found nothing. Tonight I will enable those process to work on start up again and see what happens.
I will post the information tomorrow.
Aug 02, 2010 | Acer Aspire One PC Notebook
Acer Laptop Aspire 5315 Continuous Beep on Start Up
its either there is a stucked key on your keyboard or you have a bad ram (memory card).
Jun 11, 2010 | Acer Aspire 4315 Notebook
I just bought a brand new Acer Aspire One and have keyboard issue
It's most probably a shipping damage. The keyboard is connected to the mainboard using a very thin and very breakable plug. They use this kind of plus so that they can save up space. You should get another laptop or a full refund since it is not your fault.
Feb 15, 2010 | Acer NSK8458AN Keyboard
Battery not charging. Computer is brand new. Works fine when plugged in, however icon below reads 0% charge available, plugged in, not charging''. I took the battery out and reinserted it, and still no...
If the Acer is brand new then it is under warranty. Take it back to where you bought the Acer and get it fixed under warranty. if you attempt to fix it yourself you will most likely void your warranty.
Dec 26, 2009 | Acer Aspire 5535-5050 Notebook
My acer laptop
Computer never stops beeping or has solid beep. When a computer is first booting and continuously beeps or never stops beeping
Good Luck/Please dont for get to Vote.Thank you
Dec 19, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
183 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
