Question about Frigidaire GLTF2940ES Front Load Washer
Figidaire Fron Load Washier
When I close my washer door it click but the door light will not switch on and there is a error message and also has LOC. The washer wont start. What is my problem? Thanks
  • Manikam Pillai Jun 07, 2007
    The wire is ok. All other lights come on. Just the door lock light does not switch on.
  • Anonymous Nov 04, 2007
    My machine is giving me an LOL message. When I try to push a button to cancel load, start load, or anything else - it will show the LOL then blink between that message and the number of minutes I have selected for that type of wash load. I can switch the load type (it is a dial) but it doesn't help. I tried unplugging it and coming back later to plug it in. It STILL LOL's me. Is my washing machine laughing at me?!? :) *lol Can you help me stop it? Thanks.
  • 883 Answers
Check that switch for electrical connection. Perhaps a wire came off.
Posted on Jun 06, 2007
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I HAVE A FRONT LOAD WASHIER WHEN i PRESS THE BOTTIN IT CLICKS AND DOES NOT GO ON MESSAGE fL Do I need a new board?
no, this is what it means :
"F/dL" Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My friidaire washer will not start. The door lock light will not come on. The door closes properly. The error LOC comes on. Not sure what else to do. Doesn't seem to be any problem closing the door. Help...
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
LOC error
that can be the door lock with out knowing more its hard to say
Apr 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Front Loader - LOC & Error Codes
You need to switch the machine off at the wall and leave it off for a few seconds. Open the door. Switch the machine back on again and close the door firmly. It should be o.k.
Aug 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
