Question about Fender Squier Std Strat Mn Car
Need help putting my guitar together
Iv had my guitar 4 about a year now and have only just got it out and havent got a clue about anything to do with them so i've bought myself a tutorial dvd. my problem is theres a handle type thing that came with the guitar that screws in near the base of the strings and the volume control etc. iv also got a spring with two different allen keys, i wanted to no how to put this on correctly and is the spring anything to do with it and if not what would it be for. I also have no instructions thats why im asking on here.
Please reply
Thanks
The "handle type thing" is a Tremolo or, more often referred to as a "whammy" bar. The thing at the base of the strings is called a bridge. Looking at the strings, there should be a hole to the right of the smallest string. If your "handle" is threaded, stick the threaded end into the hole and rotate in a clockwise motion. Once is hits the bottom of the threads, back it off one turn and gravity will let it hang out of the way while you play. If there are no threads, it will slip in and you will feel a "click" when it's in the proper position.
On the back of the guitar, there is a cover plate that covers the cavity where the springs are located that make the "whammy bar" work. The springs hold tension on the bridge so you can tune it and play normally, but let the "whammy bar" stretch or release tension on the strings when you push or pull it. If you already have springs inside the cavity, the extra spring you have will let you add more tension to the bridge, but you probably won't need it. If there are no springs already installed, you can install your "extra" spring in there to give you the flex and spring for the "bar-handle" to work properly.
To install a spring, loosen or remove your guitar strings, open the cover on the back, and install the spring over the hooks on the bridge and the hook on a metal bar on the other end of the cavity. Replace the cover, insert your "handle", and wiggle-away.
The allen wrenches are most likely for adjustment of the moveable pieces that support the strings on the bridge. The bridge has adjustments for up and down, and forward and back to adjust the height and distance where the string is supported. Don't adjust the bridge supports unless you loosen the strings. It is highly recommended that you don't make any adjustments yourself unless you are familiar with the mechanism. You can adjust your guitar where it's impossible to keep in tune if the adjustments are not perfect. There are usually guitar repair shops close by and offer "set-up" services to get your instrument adjusted properly. It's well worth the money to have it done right, and the service people with often teach you many things that will help keep your instrument playing well.
Hope this helps.
Jim
jimmydsmith@cox.net
Phoenix, Az
Posted on Jan 10, 2009
I have a egmond guitar, serial number 71122269. Can somebody advise what year this was made and where?
It was made in Eindhoven Holland. Egmond produced large quantities of guitars with models from cheap to quite good, for that time.
The serial number does not date the guitar, you have to look for other clues, as here
http://web.archive.org/web/20120511064338/http://www.egmondguitars.nl/dating.html
Jan 10, 2017 | Music
How do i connect eurolive vs1220f?
Hi
I'm sorry if this isn't going to be as helpful as we would both prefer but it will explain your problem if nothing else. I have managed to find a manual for this kit here:-
http://www.behringer.com/assets/VS1520_VS1220F_VS1220_M_EN.pdf
and unfortunately it says:
"Using 1/4" TS speaker cables, lug the power amp output into the 1/4" input on the back of the speaker. DO NOT use the instrument cables(i.e., guitar cords) for this connection!"
This has made things clear to me anyway. This is just a speaker and has no other circuitry, because of this you must have an amplifier of some sort between your guitar and this speaker in order to hear anything. As long as the speaker is plugged into the mains supply, and a suitable amplifier there is no need for an on/off switch, everything is controlled from the amplifier.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Behringer Eurolive Vs1220f High...
My 3rd guitar string sounds bad
Get it a repare at guitar center they have a pack of guitar strings for 5-10 Dollers they are located in Oregon Washington cailfoina if you relly want a cheep guitar that sounds good get bc rich or finder or eipcphone your guitar strings are probley getting old you have to buy a certain brad of stings that well last a year and if you need tuneing you can download an app for online tuning or you can type in online guitar tuneing I hoped this helped give me a message if you need more
Nov 25, 2012 | Dean Guitars Dean Ml Xm Electric Guitar
When I turn on the amp, I get a loud hum. plugging into the jack doesn't change anything. turning the dials doesn't change anything. when I turn off the amp it makes a loud crack.
i) Disconnect one lead of loudspeaker & insert an open-ended guitar cable into headphone socket.
ii) Put a dc voltmeter across open end jack then turn Frontman ON for a few seconds.
iii) The reading should be about 0volts - if the voltage is high (27v), then it is likely that the PA chip TDA1514A has blown.
iv) If,however, the voltage is correct in iii) , then reconnect speaker & put guitar cable into the POWER AMP IN socket & connect other end to guitar...Turn on briefly, if there is still hum then fault is in the output stages & will require chassis removal to solve.
Feb 23, 2011 | Fender FrontmanTrade 25r Combo Guitar...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
Line 6 Spider IV 30 I have the above amp and there seems to be a short when the guitar input jack makes contact with the chassis. There's a copper contact pad on the sub board that the jack is mounted...
Typical guitar input on a schematic for line 6 shows an inductor between the input jack sleeve connection and the "earth" or safety ground.
I do NOT understand how you could fry one of the voltage regulators via the guitar cable unless you have more than a guitar (other devices) connected to the jack.
ALWAYS power any interconnected audio equipment from the same receptacle or power source to avoid ground bounce/fault damage to equipment.
Jan 08, 2011 | Line 6 Line6 Spider IV 30
I was given a Marshall MG Series 15 DXF guitar amp. The input jack has been twisted off and broken out of the circuit board. I would like a diagram of this part of the circuit. OR Is this soldered to...
Typically these input jacks have 3 or 4 "tails" that solder to the circuit board. The best thing is to get an exact matching jack. You can search for 1/4 inch jacks with matching profile at Digikey.com, Mouser.com, and try www.tubesandmore.com/
In the future ALWAYS loop the guitar cord through the handle so plug is not yanked sideways when people trip over the cord.
Dec 14, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
My line 6 spider III 15 watt amp isnt working properly. i turn it on but i get this sound when its connected to the guitar. it sounds like when a guitar is not connected to a guitar and the guitar cable is...
While it could be true that you're having a problem with the guitar or cable as the previouse expert suggested, to say that it can't be anything else is false. It could be a jack problem...it would only be apparant when the jack is making contact with a cable. I do think you should test it with another guitar and another cable but if that is not solving the problem then I bet it's a problem with the input jack of the amo itself or even one of the ionternal components (this is a digital amp and there are MANY components and settings that can trigger a problem like this) If the problem is not solved with a new cable/guitar configuration then it's time to take it to the shop.
Jul 09, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Yamaha BB450's year (bass)
supported here and those formats offer no clue as to where these guitars where made.
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); Supported Brands
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
The serial numbers repeat evry 10 years... you have to know what decade is likely thenfrom the Yamaha wizard: Your guitar was made on
January 15th, 1985, 1995
or 2005
Production Number: 3
Feb 08, 2010 | Yamaha Music
Digitech Vocalist Live 4 blead through
You need a directional microphone, and then it needs to be pointed away from the guitar. Another technique would be to provide some acoustic insulation between the mic and the guitar, like a wall or a partition like what is used to set up office cubicles.
Feb 23, 2009 | Digi-Tech Digitech Vocalist Live 4...
Fender Squier Std Strat Mn Car Logo
202 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
