Question about Microsoft Windows XP Home Edition
Microsoft .NET Framework
This error comes up immediately at startup. ''Object reference not set to an instance of an object.'' Then, in details, it says: See the end of this message for4 details on invoking just-in-time (JIT) debugging instead of this dialog box,
How do I do this?
Bette Hansen
scwfun@cox.net
  • 1 more comment
  • scwfun Jan 10, 2009
    I tried the suggestion which was given to me and it did not work. What next????
    Bette Hansen
    scwfun@cox.net
    Bette Hansen
    scwfun@cox.net
    Can you give me the .NET Framework thread again
    scwfun@cox.net
    President:
  • 948 Answers
This error may have nothing to do with your .NET installation. Some programs do not work well with .NET framework. Have you recently installed any software or updated any?
If you try updating your .NET framework and it does not work, post a list of everything you have recently installed or updated
Posted on Jan 10, 2009
  • 837 Answers
If you are not up to service pack 3 on XP .. you must do that first ...
    Brigadier General:
  • 5,158 Answers
Startup of which program... or do you mean xp itself ?
  • 818 Answers
Http://support.microsoft.com/kb/940104/en-us
See this or
http://support.microsoft.com/kb/911300/en-us
or
http://support.microsoft.com/kb/810098/en-us
    Sergeant:
  • 431 Answers
Try installing the .net framework again in a new user account. If you ahve any othe server running behind close it and try again.
    President:
  • 2,110 Answers
To resolve this problem, register the Adodb.dll file in the global assembly cache (GAC). On a computer where only the .NET Framework is installed, the file Gacutil.exe does not exist.. Either obtain the gacutil file by installing Microsoft .NET Framework SDK, or create a Visual Studio.NET setup project that uses the installer to install the correct components.
To register Adodb.dll in the GAC, follow these steps:
  1. Click Start and then click Run.
  2. In the Run dialog box, type the following command, and then click OK:
    C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705\gacutil /i C:\Program Files\Microsoft.NET\Primary Interop Assemblies\adodb.dll
    Genius:
  • 1,550 Answers
Source:micrsoft.com
  • SAM ANDERSON Jan 10, 2009
    To
      Run.
  • Microsoft Master
  • 19,396 Answers
Invoking the debugging does not help, you need to update Windows Net Framework, but do a system restore first.
  • Ginko
    Ginko Jan 10, 2009
    This message comes up when you have either a missing or corrupt Microsoft .NET
    Framework Version or a missing or corrupt
    DirextX installation.
    If the problem started recently, start doing a system restore to a date before you started having the message.
    If that does not work, to fix it reinstall Microsoft .NET Framework.
    Download link here
    X64 version here.
    Direct X here,
WHAT IS VB.NET?
Visual Basic .NET (VB.NET) is an object-oriented computer programming language that can be viewed as an evolution of Microsoft's Visual Basic (VB) which is generally implemented on the Microsoft .NET Framework. It is a competing technology to Sun's (now Oracle's) Java 2 Enterprise Edition framework.
Sep 15, 2010 | Computers & Internet
The application failed to initialize properly (0xc0000135).
When attempting to run Microsoft .Net based applications, you may get the following error on startup:
The cause of this error is that the Microsoft .Net framework is not installed or is damaged in some way. Therefore applications will fail to launch.
To fix this error you can run Windows Update and find the Microsoft .Net framework update to install. Alternatively, you can download the Microsoft .Net Framework directly from Microsoft.
Aug 18, 2010 | Computers & Internet
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; WOW64; Trident/4.0; GTB6.3; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; Media Center PC 5.1; .NET CLR 3.5.30729;...
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C)
Timestamp: Wed, 15 Sep 2010 02:16:25 UTC
Message: 'oldIframe' is null or not an object
Line: 39
Char: 4
Code: 0
URI: http://assets.frontierville.zynga.com/production/R.0.9.005.22629/js/flash_integration.jsgz
Jan 26, 2010 | Microsoft Internet Explorer 8
I'm getting an error "Instance Failure" in C#.net windows based application in the login form after entering the correct info in login form
instance failure appears wen u have created an object for a class that instantiated it during run time. that is check ur classes for which u created objects and see with which object u have accessed the action of login form.
Oct 27, 2009 | Microsoft Visual Studio 2008 Professional...
Ihave an error on my Desktop my lexmark is the problem error object doesn't support this action URL:file///c/Documents%20setting/owner/Application%20Data/microsoft/internet%20 Explorer/Desktop/htt
/aspnet_client/system_web/2_0_50727
and copy the folder CrystalReportWebFormViewer4 that i found in C:\Windows\Microsoft.NET\Framework\v2.0.50727\ASP.NETClientFiles in the 2_0_50727
folder i created above...
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
I have been trying to download the drivers for Lexmark printer Z53 for a week. I've tried several times on two different computers and keep getting error "message 1603 error installing Microsofft.net...
Windows Update error code "0x643" and Windows Installer error code "1603" are generic error codes. Typically, these error codes mean that the update was not installed. These errors codes are usually caused by a corruption in the .NET Framework installation or by an inconsistency on the MSI database state.
Method 1: Manually remove and reinstall .NET Framework loadTOCNode(2, 'resolution'); To manually remove and reinstall the .NET Framework, follow these steps:
  1. Remove the .NET Framework.
    1. Click Start, and then click Control Panel.
    2. Double-click Add or Remove Programs.
    3. Note each version of the .NET Framework that is already installed on the computer. Then, uninstall all the versions of the .NET Framework.
    4. When you are prompted, restart the computer.
  2. Use the Windows Installer CleanUp Utility to clean up the MSI database state for all the versions of the .NET Framework.
    1. Download the Windows Installer CleanUp Utility. The following file is available for download from the Microsoft Download Center:
      Download the Windows Installer CleanUp Utility package now. (http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe)
      For more information about how to download Microsoft support files, click the following article number to view the article in the Microsoft Knowledge Base: 119591 (http://support.microsoft.com/kb/119591/ ) How to obtain Microsoft support files from online services Microsoft scanned this file for viruses. Microsoft used the most current virus-detection software that was available on the date that the file was posted. The file is stored on security-enhanced servers that help prevent any unauthorized changes to the file.
    2. Install the Windows Installer CleanUp Utility as an administrator or as a user account that is a member of the local Administrators group.
    3. Click Start, point to All Programs, and then click Windows Install Cleanup.
    4. In the Windows Installer CleanUp Utility, remove all Windows Installer applications for the .NET Framework.
  3. Restart the computer.
  4. Download and then reinstall all the versions of the .NET Framework that were previously installed on the computer.
    To download the .NET Framework 1.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en) To download the .NET Framework 1.0 Service Pack 3, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en) To download the .NET Framework 1.1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en) To download the .NET Framework 1.1 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en) To download the .NET Framework 2.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en) To download the .NET Framework 2.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en) To download the .NET Framework 3.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en) To download the .NET Framework 3.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en) To download the .NET Framework 3.5, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en)
  5. When you are prompted, restart the computer.
Note When you have reinstalled all the versions of the .NET Framework, you can use Windows Update to check for updates to the .NET Framework.
Dec 02, 2008 | Office Equipment & Supplies
An unhandled exception has occured .......
An attempt was made in a program or script to use an object before creating the object. For example:
dim SomeObject as Object
SomeObject.attribute = "string value"
will generate thie error message because the SomeObject that is being referred to has not been created. For this, we need the New keyword:
dim SomeObject as New SomeObject
will run without errors
Nov 19, 2008 | Microsoft Windows XP Home Edition
Windows tries to configure photo gallery and Microsoft .net framework pops up and tells me an unhandled exception has occurred in a component in my appliciation. Click continue and appliciation will ignore...
Cancell out the install. It will take several time, but it will stop.
Then:
Go to Microsoft's web site and download the newest version of .Net Framework. I believe 3.0 is latest.
Please remember to rate all users who assist you for free :)
Oct 01, 2008 | Computers & Internet
Have a error show up as HP image zone-error states X the program has encountered an unexpected error.: object reference not set to on instant of an object
this error is caused when i tried to bind data in grid view in visual studio 2005. the procedure which i followed are as follows, first i have selected choose data sourse in the grid view task and then i selected new data source. then in the data source configuration wizard i have selected database and moved further. then i have clicked the new connection button and entered all the details and clicked test connection, i get the message 'test connection succeeded' after that when i click ok in the add connection page i get the error 'Object reference not set to an instance of an object error'.
Aug 15, 2008 | HP Computers & Internet
Microsoft Windows XP Home Edition Logo
524 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
