Question about Exercise & Fitness
I have a proform 625 treadmill that slows or stops after 1 minute. I did what was suggested and cleaned the speed sensor and even adjusted it closer to the pulley. The motor also still hums when it stops. If I get off of it then it usually picks back up for a minute. Maybe bad speed sensor?
    Top Expert:
  • 12,223 Answers
This hapeen because the system has protection itself, to due the lack of maintenance, by that reason you must LUBE the deck belt, maybe you have a WORN deck belt.
2) LUBE the rollers bearing too
3) Test the drive belt motor for cracking or worn belt.
4) Test the input voltage motor, if there are the motor need replace
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
I have a proform 625 treadmill that slows or stops - 11_29_2012_11_40_22_am.gif
Posted on Nov 29, 2012
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
SOURCE: Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
  • 3 Answers
SOURCE: Treadmill will not maintain the correct speed.
your belt may not be tight enough and it is slipping which can cause it to move faster than the motor
Posted on Aug 26, 2009
SOURCE: treadmill belt runs very slow and stops when I get on
proform 625 belt slips cause
Posted on Jan 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Posted on Apr 26, 2010
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
My proform j8 speed up button does not increase speed
1) adjust the speed sensor, test it, clean it, and tight the connector very well. se the diagram
2) RUN The software calibration for troubleshooting, and fix it. go under the hood motor and follow the instruction or read your instr. manual very well how to enter in the s. calibration
God bless you
Nov 12, 2012 | Proform Exercise & Fitness
My proform 3.8 treadmill isn't running at the
see the diagram attached adjust the speed sensor, clean, and tight the connector very well.
2) Run after you did the adjustment the software calibration for diagnose, troubleshooting, and fix it.
sincerely. God bless you
May 01, 2012 | Proform Exercise & Fitness
My proform xp slows below the set speed, the motor wines and after forty minutes starts to smell
Dear Sir:
Please RUN THE software calibration for easy diagnose and troubleshooting, and adjust the speed sensor see the diagram attached.
And you will see the problem with the motor, possible lack of LUBE, and maintenance.Now you test the motor for lubrication and maintenance too.
Apr 20, 2012 | Proform XP Weight Loss 620 Treadmill
Proform 625 Ex
Check and clean the speed sensor near the motor pulley. If the speed sensing have some problem then the system will stop the motor to avoid further damages to the user. I have added the picture of the speed sensor You can see The cylindrical portion near the motor pulley
Ajin
Jan 19, 2012 | Proform Exercise & Fitness
Can I dismantle proform 360p to move it
When plugging my treadmill in it was going at max speed without the key even in. Now it has slowed to a complete stop and I can not get it to move. The incline works, but not the speed.
Jul 08, 2011 | Proform Exercise & Fitness
Proform 765 EKG
Aug 10, 2009 | Proform Sport 1000 Folding Treadmill...
Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Jul 30, 2009 | Proform CrossTrainer Treadmill
Treadmill stops running
I had simillar problem. I have proform 830 QT. My trademill stops after 10 minutes of work out. Everything shuts down and the circuit breaker pops out.
Root cause:- no lubrication under walking belt. Caused the moter to over work (over heat) and hence te circuit breaker popped out to prevent blowing of motor.
Solution:- Apply the lubricant under walking belt and adjust the belt tension if needed.
Back ground:- Contact proform customer service at 1-888-533-1333 (http://www.iconservice.com/proform/faq_tread.html) and buy the treadmil cleaning kit or lubricant kit which comes with a wand for easy application. It may cost you 35 dollars including shipping. If you need to fix your treadmil right away, use NAPA silicon spray 8300. Proform actually tells do not use it as it may damage your belt. However the specialst who came to fix my treadmill just sprayed it and collected 100 dollars. When I called proform they told me lubricating will fix it and its my mistake to not trust them. I guess they knew exactly what they were saying.
Dec 03, 2008 | Exercise & Fitness
Exercise & Fitness Logo
274 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
