Question about Hotpoint Kitchen Ranges
(The wiring connections are completely different on the new part (part #WB27x10215) than on the old part (pictures upon request).Where can I find the diagram to connect the new control?
  • 182 Answers
SOURCE: replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
Posted on Jul 04, 2008
pierre1811
  • 144 Answers
SOURCE: I have Bryant HRV and the motor has failed.
Wire nut and tape the blue and red wires they are not used.
Posted on Mar 06, 2009
mechanicm639
  • 253 Answers
SOURCE: 2001 Chevrolet Impala 3.8 fuel pump wiring diagram
The wires should be grey, orange and black, purple, and a black wire. The purple goes to purple, grey to gray. The orange and black goes to the small black wire on your car harness and the black goes to the bigger black.
Posted on Apr 30, 2009
  • 94 Answers
SOURCE: Please help me i need the Lighting Control Module diagram
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm1of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm2of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm3of3.gif
follow the three links for complete wiring diagram of lcm
Posted on Jun 30, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
Wiring diagram
You bought from Autozone,and now you have to splice,look at both and use the same wires from old pump to new one,look at both connectors and do it the same as in both plugs..
Jan 17, 2014 | 1998 Isuzu Rodeo
I am replacing the 3 speed fan switch in a ceiling fan. Upon removal of the old switch (due to a cracked/broken screw port), I noted the secific wire and color that was located in each of the four...
Use a continuity tester on old switch.
There will be 1 main wire that connected to power >>> power flows through this wire to the switch and feeds the other 3 wires > each time you click switch, power will flow to one of the other three wires
The do the same test on new switch. Match up wires accordingly.
If you don't have a multimeter, buy inexpensive continuity tester at hardware store.
Continuity tester is basically a flashlight battery and flashlight bulb that lights up when the circuit is closed
Oct 16, 2010 | Gardner Bender Gsw-34 3 Speed Pull Chain...
Power failure upon pressing shutter button
hi
dear ur battery is not working properly replace the battery
Dec 14, 2009 | Canon EOS 40D Digital Camera
Wiring compatability
The best thing to do is go and spend about 5 to 10 dollars and get a wire adapter from radio shack or any parts stores. It makes it real easy you can wire everything in your house walk out plug it in and away you go.
May 24, 2009 | 1994 Nissan Quest
JBP24G broiler stuck on
I think you are right on with your relay comment. All the relays are an integral part of the control timer assembly (part number WB27X10215). Generally, you will be able to transfer the clock overlay from the old control to the new one, so no need to order the overlay. Not very difficult to replace.
Feb 25, 2009 | GE JBP24 QuickClean Electric Kitchen Range
MSI MS 6309 case connector wiring
hi steve
do you have acess to some thing that can show me a photo of what you need assists in or the page you are looking at so i can review the same document you are viewing so we can determ what they want. there must be some different abour v1.1 and v2.1, the size of the board or the board layout, the design, msi configuration is different, power supply location, or the high-th maybe the differance, the list can go on to infinity, set the board in front of you, map out the connection, trace the old wire pro the old equipents, see if they have the same amount connections and plug ins, if they are different than find out which items have different connector contact the manufacture ask for the engineering department and or wirining diagram layout, find out which wires color are used and which one core a late with the new board and remove the old ones, i had a system that had a different speaker pin layout and trace all the wires for the new set of wires, the old one had two 2 ground wires as the new one only had i ground wire i had splice the two 2 ground wires together.
if you need more help please contact me or leave me a phone # where i can call you and i will help you figure out the new design.
i love a chenallenge.
rod gandy the candymangandy
Feb 06, 2009 | Intel Motherboard
Which wire is power and ground
generally red is the ignition wire, black is ground, orange is 12+ all the time, a yellow could be the same....it would be more helpfull if you would give the model number of the eq
Jul 13, 2007 | Kenwood KGC-4042A 5-Band Car Equalizer
Kitchen Ranges Logo
37 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
