Question about Samsung Televison & Video
Un46b7000wfxza bars running from top to bottom
  • 4 more comments
  • Richard Gigliotti Dec 02, 2012
    Neighbor across the street had a samsung almost same age. It had several barrs in picture like jail barrs. it is not the filter.
    Covered by extended warranty. They installed the T-Com module. that fixed the problem. I installed a T-Com module and it did not fix the Jail Bars.
    Samdung repair/dealer says the problem is the display screen. $650.00. Plus labor. Problem looks simular but solution not the same.
  • Richard Gigliotti Dec 06, 2012
    Update on solution to jail bars. Two days later(from 12-02-2012) jail bars returned. They show up when set first turned on and stay for appx. five min. then clear up. The Warranty repair said they will send a tech out to examine problem.
  • Richard Gigliotti Dec 14, 2012
    Latest up date as of 12-11-2012. The warranty repair co. decided the problem is the "display pannel" and will recommend to Samsung to replace it.
    Because of the cost of the display pannel, Samsung, Via Best Buy, decided to give the customer a new TV.
    Top Expert:
  • Samsung Master
  • 74,198 Answers
It indicates the input signal interference. Might be of a faulty main filter capacitor too. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 29, 2012
UN46B7000WFXZA...Samsung tv
Could be an open internal fuse or power supply failure
Jun 28, 2016 | Televison & Video
Top and bottom menu bars are different colors, I made bottm pink but top won't change color?
make sure that the "Let windows choose... " is turned off otherwise windows takes over.
Tony
Apr 27, 2014 | Gateway Computers & Internet
Samsung UN46B7000WFXZA loses display after movement or motion
Please check up all the cables and connectors and tighten them.
Jan 01, 2014 | Samsung UN46B7000WFXZA 46 LCD 1080p HDTV w...
HOW TO CHANGE A BELT
Hi there...You will need a Phillips screwdriver to get the bottom cover off.Remove the screws and then remove the bottom cover.Clean out any excess dirt in the general area of the roller bar and motor assembly area.Place one end of the belt over the steel shaft of the motor and then roll the other end of the belt on to the end of the roller bar.placing the belt on the top of the roller bar and roll the bar slowly and feed the belt onto the roller bar until it is completely in place.Replace the bottom cover and put all the screw back in.
Plug your vacuum in and turn it on with the roller bar off the floor, in other words let it run for 10 seconds until you put it on the carpet allowing the belt to position itself properly on the roller bar.
Jul 03, 2012 | Kenmore 31913 Progressive Direct Drive...
Blue bar from top to bottom
Before you suspect the TV try to play first the DVD on your TV to test if the problem is on tV or on the cable setting,reception,and any other problems related to TV digital cable..
Mar 06, 2012 | Televison & Video
DEGX1 that was not heating correctly. Cleaned behind lint trap and pushed the reset button (did not feel tripped though). My question concerns the "Sensor Conductivity" or two chrome bars at bottom of...
Make sure that onw wire is coneected to the top bar and one wire connected to the bottom bar. DO NOT connect both wires to one bar, it make short out the control circuit. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum make further help you through your problem.
Sep 19, 2010 | Fisher and Paykel DEGX1 Electric Dryer
THE TASK BAR APPEARS AT THE TOP OF THE WINDOW
First, make sure the taskbar is not locked. Right click the taskbar and make sure the is no check mark beside 'Lock the taskbar".
Now, point your cursor just beside the START button (outside the START orb and on the task bar), click and hold and now you can move it to the bottom of the window.
Jul 13, 2010 | Dell Computers & Internet
How to fit a odyssey g3 gyro set
Hi MonkeyManTim
Firstly, remove the centre lock nut on the stem. This loosens the stem/headset. Pull the handlebars up and rest them next to the front wheel, make sure the brake cables aren't being stretched too much.
You'll see there is a locknut on the headset (at the top of the frame/top tube where you pulled the stem from) and loosen this (might need a massive spanner!).
Pull offthe toppart of the headset, ball races and lower part. Replace with the gyro bottom and top parts. Grease the ball bearing if they aren't already!
Slide it together, fit the stem and you'll notice the brake lines that come with it. Undo the rear brake, run the splitter cable from the front lever to the top half of the gyro, same with the bottom half. I found putting some padded stickytape on the bars helped here as the splitter cable would 'ting' off the bars.
Undo the front brake and run it through the stem hole, through the forks and cable tie it to one fork leg.
Test the brakes, adjust where necessary and on you go pulling bar-spins for fun. Please don't land a jump with the bars half spun, it hurts....a lot!!
Jun 22, 2010 | Mongoose 20-Inch Gravity Games BMX...
Jail bars in picture on analog cable tv only
this kind of intermittent noise has to be researched in the bench specially because the lines are there and then go out. it can be any component false contact, or solder joins.
Apr 15, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Televison & Video Logo
43 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
