Back to:
Tags:
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Cannot get new belt on
posted by jennyg on Jun 06, 2007
We removed plate and roller brush, but cannot figure out how to remove the driver shaft to install new belt. Old belt was already broken so we did not undo belt.
Comment by jennyg, posted on Jun 06, 2007
It is not the motor shaft, but the driver shaft or the other little wheel that the belt is supposed to go around. The roller brush part we get, but when we try to remove the other wheel or diver shaft, it will not come out and there is no way to access it. When we changed the belt the old one had already busted, therefore we did not see how it was originally. I have changed a lot of vacumn belts and no it should be simple,I am not sure what we are doing wrong. the vacumn is only about 9 months old.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
tresilla
Rank:Guru Guru
Rating: 86%, 1191 votes
no need to remove motor shaft which is integral with motor. slip belt on motor shaft first, then on roller then pull roller back to correct position. needs a little force
Rating Locked! (?) jennyg has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on cannot get new belt on:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Hoover U8145-900 Savvy Bagless Upright...
When I depressed the pedel to lower the handle on our...
all debri stays on filter and wont go to the cartridge i...
Cannot unscrew the area w/ the wind nozzle......it doesn't...
my roller came out when replacing the belt and i lost the...
I have a Hoover Widepath Fold Away, 12 amp motor vacuum...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
