Question about HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop
Compaq presario sr1420nx turns on makes one beep then resets in continual pattern doesnt get to boot up
  • HP Master
  • 5,660 Answers
To go with my other solution to you;
You press the Power On Button. This in turn presses the Power On switch, located inside the plastic assembly; of the Power On Button.
When the Power Supply is connected to power (Plugged in), there is always a constant 5 Volts present. (DC Voltage)
This is the 5 Volt Standby power.
Pressing the Momentary Contact Switch, the Power On switch; closes a circuit, momentarily.
The Soft Power On circuit.
This 'excites' the Power Supply, and turns it on.
(Sounds like the start of a steamy novel)
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System is activated. (BIOS program)
BIOS looks to see what devices are connected, DOES a Ram Memory count, and turns the Processor on.
Then BIOS hands the computer over to the Operating System.
(Windows)
ONE beep indicates BIOS has done a Ram Memory test, and everything is OK.
Now next we have BIOS turning the Processor on.
Then handing the computer over to the O/S.
Due to what is going on, as stated in my other solution to you; the Processor is turned on, BIOS goes for the boot files on the harddrive; then power problems develop from the bad capacitors; and BIOS turns the Processor off.
Just about had time to access boot files; but now the Processor is turned off, ('Brain'), and boot files on harddrive couldn't be accessed.
Now here we go again; with the weakened capacitors trying to do their job.
Cycle starts all over again, but weakened capacitors 'drop to their knees', and Processor turns off.
Over, and over; until capacitors fail all the way, and Nothing happens.
Regards,
joecoolvette
[ !O_O! Martha I think the boy's done lost his mind! lol! ]
Posted on Nov 29, 2012
5 Suggested Answers
  • 579 Answers
SOURCE: compaq presario sr1420nx fan noise
Just replace the fan. They are a standard commodity and not hard to change. Get a good one this time. You get what you pay for.
Posted on Feb 14, 2008
  • 942 Answers
SOURCE: compaq presario sr1420nx video i need the driver
Hi...
You can use this site below to download a driver of your hp unit.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=457247&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
Select if what type of Operating System did you use.
Regards
PCmania
Posted on Sep 25, 2009
  • 13 Answers
SOURCE: COMPAQ PRESARIO SR1420NX, TRYS TO POWER UP BUT
Could be one of two things: either the power supply is going bad or the RAM is either going bad or isn't seated properly inside.
First thing I would try would be to re-seat all the memory chips inside the computer. There could be up to 4 sticks of memory in some computers. If this doesn't work, try pulling the memory out of the computer one stick and a time and booting the PC. If it boots, you've found your bad memory stick. Put all the others back in and replace the faulty one.
If none of this works, you might consider calling HP (maker for compaq) for support on getting the power supply replaced.
Posted on Jan 22, 2010
bronk50
  • 27725 Answers
SOURCE: compaq presario sr1420nx wont turn on fan keeps going on an off as well as green light
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Hope this helps.
Posted on Nov 26, 2012
Compaq presario sr1420nx fan noise
Feb 14, 2008 | HP Compaq Presario SR1420nx...
How to open compaq presario sr1420nx computer
You have a virus in your computer. Boot the computer, immediately hit the delete key until you can get to the setup screen and it will allow you to format your drive.
Nov 28, 2012 | HP Compaq Presario SR1420nx...
COMPAQ PRESARIO SR1420NX, TRYS TO POWER UP BUT GREEN LIGHT ON FRONT POWER BUTTON JUST FLASHES..
Jan 19, 2010 | HP Compaq Presario SR1420nx...
Video driver to Presario SR1420NX
logon to driversguide website, register as a user and search for the drivers u will get it there
Oct 14, 2009 | HP Compaq Presario SR1420nx...
My compaq presario doesnt properly boot....the power botton lights up and it seems booting but can not continue... it automatically tries to reboot every after 25 seconds...
you must know that RAM causing improperly booting and makes your computer automatic rebooting. and can make also your windows corrupted.
Aug 11, 2009 | Compaq Presario Notebook
COMPAQ presario 5152
what version of windows are you using?
if you have windows 95 or 98 follow the instructions here:
http://www.computerhope.com/issues/ch000211.htm
Dec 29, 2007 | HP Compaq Presario SR1420nx...
Compaq Presario V2000 boots up, but
Getting into Windows Safe Mode Users who may not be able to boot into normal mode or are not able to ... "F8 Key.
Linux and UNIX pg command help |/pattern/, Start up at the first line containing the regular expression pattern. filename, A path name of a text file to be displayed.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Theses site should get ya back on line. Read and follow instructions.
Merry Christmas, Good Luck...Please dont for get to Vote/Thank You.
Merry Christmas
Dec 22, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
