What two wire can i put together to bypass the timer so the heat will come on dryer
SOURCE: we need to know what wires to hook together to
lift the top up on your dryer.this will require a wide,flat tool @ front corners.a flat screw driver will work but a stiff putty knife is ideal.lift & pull.the door switch is in the upper right hand corner.when you raise the top & lean it carefully out of the way you will see the obvious door switch wires.pull them off of the switch & put them together w/ a clothes pin.you can bump the start button w/ the lid still up.if it starts up,its the switch.
SOURCE: Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the
dryer. A blown fuse will show no continuity when measured with a
meter. Before replacing the fuse, make sure the blower wheel is not
broken or clogged, and there is nothing blocking the venting.
SOURCE: Dryer will not heat up
It sounds like you have a loose wire on one of the thermal fuses or thermostats. Or, there is a high limit thermostat that is going flaky and only working sometimes. Good luck.
