Question about Frigidaire GLWS1233A Top Load Washer
Washer will fill and wash/agitate, but will not spin or drain.
Drain hose is at proper level and is not restricted. Impeller is free of obstructions. Washer has worked fin since it was purchased in Nov 2005. It has made no unexplained noises or produced any odd odors.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
You will need to replace the lid lock assembly. Here is the part to order.
Posted on Nov 29, 2012
  • 37 Answers
SOURCE: Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Posted on Jan 17, 2008
  • 71 Answers
SOURCE: Washer will not spin
My mum had this problem. I think it had something to do with the barrel coming loose.. - get a plummer ;)
Posted on Sep 29, 2008
  • 30 Answers
SOURCE: frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Posted on Oct 15, 2008
aborcass
  • 2651 Answers
SOURCE: Washer won't spin or drain water
you checke dthe drain??? how??? i would assume that you have something stuck within your drain pump assy( bra underwire-- money--- toothpick--nail/screw) VERY common issue, youll need to remove the front cover and remove the hose leading to the pump to look inside. DISCONNECT POWER-- PUMP IS ALWAYS LIVE!!!!!!!!!!!, oh yea and youl need a bag to collect the water when you disconnect the hose, YOURE GONNA GET WET!!
Posted on Oct 19, 2008
SOURCE: washer does not spin after wash cycle
Problem solved. It was one of the resolutions posted by one of your clients. TKS. PS this one of the best problem solving sites that I have seen. Great Job Rick
Posted on Jan 31, 2009
Washer keeps fling with water and will not agitates it will drain and spin
There is usually a small hose from the outer tub to the water level switch. This ia actually a pressure hose to make the water shut off. If a hole is rubbed into it, you loose the pressure and the washer fill will never shut off. That pressure is needed to switch machine from fill to agitate once it reaches the proper fill level.
Apr 07, 2016 | GE Washing Machines
AWM5145/2
check if water pump dont release water properly..u can see that in the end of drain hose ..fill the washer w/ water then set it to spin after that look the hose if the water flow properly..
Mar 08, 2014 | Whirlpool AWM5145/2 Front Load Washer
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
I have a GE washer that won't drain!
The pump is clogged. Remove the tub to pump hose and you will find debris in it not letting the pump work. Do this and you will be good to go. Thanks, Rick
Mar 04, 2010 | Washing Machines
Our washer over fills and must be manually stopped, then will not agitate, but it will spin and drain, if you advance the timer. Already replaced water level switched, and inlet valve. What's going on?
Most likely a hole in the hose going to the water level switch, and possibly at the washtub connection. If you are not getting the proper air pressure from the water level rising and compressing the air in the hose, the switch will not send the proper signal to the washer to switch from fill to agitate.
Also it is possible however not likely that you replaced a bad water level switch with a bad replacement switch.
Oct 30, 2009 | Washing Machines
My washer will not drain the water. It works by
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no blades missing/broken and that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helped and best wishes.
Sep 01, 2009 | Washing Machines
No drain or spin cycle
Check the following to address the issue--
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 03, 2009 | Kenmore 22422 Top Load Washer
FILLS WTANK WITH WATER AND DRAINS BUT DOES NOT AGITATE NOR SPINS
Hi. your timer assembly is faulty. it is not initiating the spin and proper wash cycle due to this malfunction. the timer is responsible for the actions and commands. if its defective, it will not carry out the initiations correctly.
CLICK HERE TO BE DIRECTED TO THE PURCHASE PAGE FOR YOU REPLACEMENT TIMER.
May 23, 2009 | Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
