Question about PANDIGITAL Novel 7
I have a Pandigital Novel 7" Tablet that will not turn on, what do I do?
Worked for about 2 days, then was plugged in to charge, now will not turn on.
  • PANDIGITAL Master
  • 14,641 Answers
Dear Please Try it;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Nov 30, 2012
  • 15 Answers
SOURCE: is there a compatible flash player type for
If you are referring to flash memory, yes it can be expanded with flash sd memory type sd/sdhc, mmc/mmc+ up to 32gb. You can find more information on the specs here:
http://www.pandigital.net/search.asp?Mode=Product&TypeID=43&ProductID=393
Lewis
Posted on May 14, 2011
SOURCE: how do I reset my
reset a pandigital to factory condition
Posted on Jul 07, 2011
SOURCE: I cant get the pandigital novel to turn on and it
i have the same problem
Posted on Jul 10, 2011
SOURCE: Used wrong charger on pandigital novel
I put my pandigital on the charger and it sparked and now it's not working
Posted on Nov 30, 2011
  • 1575 Answers
SOURCE: pandigital novel white stuck on blue screen
Hi
Try resetting it.But remember user data will be lost plus third party applications.
  • Hold the power up button and the volume button at the same time for 5 seconds.
Posted on Mar 02, 2012
How do i reset to factory mode if i forgot my pattern
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Pandigital Novel 7 to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Pandigital Novel 7 and including third-party applications.
9. The Pandigital Novel 7 will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Mar 06, 2015 | PANDIGITAL Novel 7
Why my pandigital novel doesn't get on when I push the button power.
I am working on one of these ask we speak, same problem - when I opened the case I saw that the solder connecting the power button to the board has broken. After a little research I learned that this particular tablet/reader is poorly made & this type of problem is common. It is possible you have the same problem...
When you first plug it in to charge it, do you see any activity? (charging indicator on-screen, firmware info, etc)?
Oct 31, 2014 | PANDIGITAL Novel 7
I lost me charger and need to order one
You can order one from Ebay for 5-10 dollars
Oct 21, 2014 | PANDIGITAL Novel 7
What do i do when i have a 7 inch pandigital tablet/ereader in white and it has the button that pops open with an error that says force close and wont let me get passed that button because it keeps po
this is about the worst tablet you can ever buy
in the future spend more than 80 bucks either way here is the help you need to fix it it is called a hard reset
How to hard reset Pandigital Novel 7 to Factory Default Setting Reset Pandigital Novel 7 to factory default setting you will lose all of your sms and apps,so you must back up your apps and sms.
These steps will show you how to hard reset Pandigital Novel 7 to factory default settings:
First, try this:
1. Go to main home screen, press the menu button.
2. Choose the Privacy
3. Press Factory data reset.
4. Read the disclaimer, then Press Reset.
5. Last,press Erase everything.
6. Restart the Pandigital Novel 7, you will see the phone as a brand new phone.
Feb 16, 2018 | PANDIGITAL 7270FW Tablet
Pandigital novel white stuck on blue screen
everytime i turn on my pandigital tablet it goes to blue screen and stays on there, until the battery dies, everytime you turn it on it goes to the blue screen and stay on there what should i do?
Mar 02, 2012 | PANDIGITAL Novel 7
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
My screen cracked across the middle, how much does it cost to fix the screen?
I recently cracked the screen on my mac. The store wanted 1200 to fix it. If the computer is usable ignore it. If it isn't buy a new computer. Broken screens are very expensive to fix...sorry mate ; c
May 04, 2011 | PANDIGITAL Digital Book 843967071153...
Pandigital novel 7" WHITE ereader wont turn on.
You can try pressing the reset button with a straightened paperclip of pin. If that doesn't do anything removing the back and unplug the battery. Leave it unplugged for a minute or two and reconnect it. Be careful unplugging it as you don't want to put to much force on the wires. You can use a small screw driver or tweezers to pry on the plug. The white plug here is what you're locking for. See if it powers on and hopefully it does. If not you may have to contact Pandigital.
Hope this helps
Ray
Mar 12, 2011 | PANDIGITAL Digital Book 843967071153...
My Pandigital EReader is frozen, it won't even go into sleep mode.
My pandigital has been frozen on the pandigital novel options for 1 full day. How can i shut it down and read the books I have?
Jan 06, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
PANDIGITAL Novel 7 Logo
200 people viewed this question
Top PANDIGITAL Computers & Internet Experts
Owen Barnes
fixya62589
Are you a PANDIGITAL Computer and Internet Expert? Answer questions, earn points and help others
