Question about Sewing Machines
Left needle not stitching what am I doing wrong
Everything else is good, but the left needle is not stitching on the material.
  • Sewing Machines Master
  • 7,365 Answers
Try changing the left needle and see if that helps the machine to sew
Posted on Nov 29, 2012
RickE1
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
Mongo32
  • 111 Answers
SOURCE: not forming stitches
needle in backwards?
Posted on Jun 13, 2009
  • 255 Answers
SOURCE: gobbs of thread gather on backside of material,
Hi! Here are two things to check that generally cause problems like this:
1. Check that you're threading the machine correctly, especially the take-up lever.
2. It may be that you need to tighten the top tension. When the top tension is too loose, it'll cause big gobs of thread, like you say, on the back of the material. All this thread is actually top thread (not bobbin thread). (I recommend using different colored threads in your top thread and in your bobbin when you suspect tension problems.)
A couple of things to remember when you are adjusting the tension:
  • Always adjust the tension with the pressure foot DOWN.
  • Thread the machine with the pressure foot UP (so the thread can slip easily into the tension disks).
  • The higher the number on the dial, the tighter the tension.
  • Adjust in small increments. Stitch a few inches, check, adjust, stitch, check adjust--and repeat as needed.
I'm in the process of posting some photos about tension adjustments on www.robbiesews.blogspot.com. Check there later tonight and I should have them up.
Let me know if this helps, ok?
Robbie
Posted on Mar 10, 2010
The fabic will not move under the foot feed tried everything !!! Hve the mauels but cant figure this out !!! help and the thread in the bobbin keeps knotting up Thanks
Are the feed dogs moving when you try to stitch? If so, are they below the needle plate so they do not make contact with the fabric? If this is the case, the feed dogs have been dropped to allow darning. Check your manual and raise the feed dogs.
Is the stitch length set to at least 1 1/2 or 2? If the stitch length is set too close to zero, the needle is practically stitching in place. Lengthen the stitch so the fabric will move as the stitch is taken.
Are you sewing very fine material? If the fabric is a very light weight, there may not be enough pressure between the presser foot and the feed dogs. Most machines have an adjustment to increase the presser foot pressure. On newer machines it is usually a dial at the top left of the machine or low on the left side of the needle. Older machines sometimes have a a round cylinder the projects on the top above the needle bar that is spring loaded. Pressing the cylinder down will usually tighten the pressure. Other machines actually have a screw at the top of the needle bar that when screwed down will tighten the pressure.
Nov 22, 2015 | Sewing Machines
My machine skip stitches
Replace the needle it might be bend and check if it is the right needle for the work you are doing. You get for example stretch needles, denim needles, needle for thick/thin yarn, thick material ect. Using the wrong needle for the wrong material can cause skipped stiches especially if it did not do it before. Clean and oil the bobbin holder and make sure the bobbin is threaded correctly. Can also adjust top yarn tension as a last option.
Apr 09, 2015 | Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
I have a Pfaff Creative 1475 CD. It only skips stitches on stretch materials. I have tried a ballpoint and stretch needle and it still skips stitches. It sews a 100% correctly on any other type of...
There are a couple things you can do that may help. 1. Float some lightweight paper under the fabric. Sew through the material and the paper. Then tear away the paper.
Secondly make sure you are using a long enough stitch.
If none of these things work.... take it in and have an example of the skipping. Have the machine's timing checked.
Oct 30, 2013 | PfaFF Creative 7570
I have a designer SE it wont stitch tee/shirt material it misses stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Feb 01, 2013 | Sewing Machines
Elna Stella TX - stretch stitches missing on stretch material
Oh yes, a ballpoint needle would indeed help.
Good luck and let me know if this solves the problem.
Jan 13, 2010 | Elna Sewing Machines
Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Nov 24, 2008 | Singer 3116 Simple
White serger 2000
Did you change to the narrow stitch finger? The narrow one is in the door of the machine where the other tools are -- a little square box on the left of where the needle box slides in. Sometimes that is needed instead of the normal one.
Caution: If you have never before changed it out, open the left door all the way and look and see where the stitch finger is coming out of before you remove it all the way. Refer to your manual.
Oct 13, 2008 | White Sewing Superlock 2000 ATS Mechanical...
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
