Question about Texas Instruments TI-83 Plus Calculator
How to set degree mode - Texas Instruments TI-83 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press MODE. Use the arrow keys to highlight "DEGREE" on the third row and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Posted on Nov 29, 2012
  • kakima Nov 29, 2012
Tip
Temp cut off/cut in
Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.<br /> Ex: In heat mode, If you set @ 68 degree, it will cut off 70 degree beginning and cut in at the end of 66 degree. <br />In cool mode, if you set at 68 C degree it will cut off at the end of 66 and cut in will be at the beginning of 70 degree.<br /><br />
on Jan 10, 2011 | Heating & Cooling
I need help on how to activate heating mode in my 7wa4501q whirlpool 6th sense minisplit pleasee
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 13, 2011 | Heating & Cooling
Have a brand new Master Temp 400K Propane with an Intellitouch and the heater shuts off at 84 degrees. Do I need to set a max temperature from the heater control panel?
If this heater has pool mode and spa mode as an option, and you need the water higher than 84 degrees, you must set it to spa mode even if it is a pool. As a regulation, these heaters come pre-set to max out at 84 degrees as a safety feature. However, in spa mode it can reach 104degrees.
Jan 11, 2011 | Pentair Mastertemp Heater
Don't have a manual i just wan't to know what settings are what ..re symbols on screen on control
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.helpful?
Dec 31, 2010 | Heating & Cooling
I have a brand new york inverter air conditioner that does not want to cool!
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Dec 29, 2010 | Heating & Cooling
My new calculator is giving incorrect answers to sin, cos, and tan problems. Is there a setting I need to switch to? For example, sin -1 (.423) = .4367 not 25 degrees
Your calculator is set to radians, which is the norm for higher mathematics. To set it to degrees, press MODE to bring up the mode editor, press down-arrow twice to get the the angular mode, press right-arrow to highlight "DEGREE," and press ENTER. Press 2ND [QUIT] to exit the mode editor.
Sep 15, 2010 | Texas Instruments TI-84 Plus Calculator
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
I am getting the wrong answers with the tan -1 function
That habit of TI, Casio, and Sharp to label the inverse trigonometric functions with the -1 superscript can cause confusions.
  1. The inverse trigonometric functions arcosine, arcsine, and arctangent (labeled by manufacturers as cos^-1, sin^-1, and tan^-1) should not be confused with the other trigonometric functions known as secant(x) =1/cos(x), cosecant(x)=1/sin(x) and cotangent(x) = 1/tan(x).
  2. To avoid errors in the use of the inverse trigonometric functions, one must be careful and set the angle unit to the one required by the problem at hand (degrees, or radians)
  3. To make the trigonometric functions really functions, their range is restricted.
  4. In this calculator arcosine (x) gives results between 0 and 180 degrees (if angle MODE is Degree) or between 0 and Pi radians (if angle MODE is Radian).
  5. The range of results for arcsine(x) and arctangent(x) is between -90 degrees and +90 degrees (if angle MODE Degree) or -Pi/2 and Pi/2 (if angle MODE is Radian)
With this information you should be able to set the angle unit correctly ([MODE][Radian] or [MODE][Degree] ) and interpret the results. If you want to extend the angle to other values, use the periodicity of the trigonometric functions.
Hope it helps
Nov 06, 2009 | Texas Instruments TI-83 Plus Calculator
The numbers are not visible on the screen and Im not able to set the calculator on the degree mode .
First try this- press the 2nd key and press and hold the up arrow key or the down arrow on the right side of the calculator a for a few seconds and see if the curser appears - if it does - than problem solved . to set the calculator to degree mode press the MODE button and find Radain, degree and hightlight it by moving the curser over it and press enter than exit it now set to degree and press sin(30 and enter and see if you get .5 as a result it it does than problem solved
Oct 06, 2009 | Texas Instruments TI-85 Calculator
Texas Instruments TI-83 Plus Calculator Logo
27 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
