Question about Garmin nuvi 780 GPS
Your answer to my nuvi 780 stuck loading maps
Thanks for trying. There is "no" reset button on the back of my nuvi. You do a re-set by turning the power switch to the left and holding for 8 seconds. Already done that and it still hasn't helped. Thanks for trying.
    Problem Solver:
  • 17 Answers
Check out this link, good luck!
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=95274&whichpage=5
Posted on Jan 10, 2009
My Garmin nuvi 265W - when you turn it on is stuck on the loading maps page.. any suggestions
do this.,
1. get it connected to ur pc and see if it seeks any software update through garmin.com
2. if no updates needed, start again see what it does, if same stuck, while stucked in loading reset it by press and hold the tiny reset button for atleast 8secs and release , it should then come back to normal.
Pls let me know the result.
Thanks and regards
Jul 30, 2010 | Garmin Nuvi 265W GPS Receiver
Garmin just shows its loading maps and then screen goes blank and it repeats this even when I hold down the button for 10 seconds to reboot Why is it not turning on?
A Garmin Nuvi 1300 freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Nuvi 765T won't load maps. Fires up, gets to the horozontal bar indicating that the maps are loading, but then goes dark and repeats. Held the on/off button for 8 seconds, but unit won't shut off. Didn't...
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Apr 30, 2010 | Garmin nuvi 765T GPS Receiver
After upoloading maps on my garmin when I unplug the charger my maps go away and I only have audio support
It's a software problem with your NUVI . It can be solved by resetting it .
To reset your NUVI please follow these steps :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 15, 2010 | Garmin nuvi 780 GPS
HI not to good on compt. my 1300 series turns on says lpading maps then powers off tried 2 methods of re booting joe kane thanks
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Apr 01, 2010 | Garmin nuvi 1300 Car GPS Receiver
Nuvi 780 stuck in "loading maps"
On the back of the unit there should be a reset button, press this in till the unit starts to turn on again.
~Phil
Jan 10, 2009 | Garmin nuvi 780 GPS
My Garmin 780 will not turn on
Hi, Try to reset by holding the 'On' button. After the reset if the Map is not loading in the background then it may be corrupted. If you can connect the GPS to the computer then you can call the Garmin support and get the MAPS which you can eventually load. If the GPS is not getting connected to computer then you need to send it to Garmin to fix it. Hope it is under warranty.
Samething happened to me. Garmin service is wonderful, they replaced it..
VM
Dec 27, 2008 | Garmin nuvi 780 GPS
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 780 GPS Logo
252 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
