Acer Aspire 5733 Series won't start
My Acer Aspire 5733 Series Model number PEW71. Will turn on every things fans and all that, but no display. Then will turn off automatically, but turns back on 2 seconds later. and if the display doesn't turn on on the 2nd time it will turn back off. for 4-5 seconds then it turns back on without display for 5 minutes, then it will just shut off.
    Novelist:
    Champion:
  • 233 Answers
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/intocircuit-acer-aspire-5733-ac-adapter-65w-19v.html
Posted on Nov 30, 2012
  • 433 Answers
SOURCE: Acer Aspire 9303wsmi display problem, 1 long beep, 2 short. HELP!
What you hear are bios beeps. They signal you that something is wrong. These beep's vary by the manufacturer of the bios chip that you have.
You can find out what bios you have by looking at your manual. The common cause for one long and two short beeps is a video problem.
Either the video chip on your mobo is shot, or your video card needs attention.
Hank
Posted on Aug 04, 2009
babes_ganda0
  • 381 Answers
SOURCE: Acer Aspire 3003LCI Laptop Fan starts but stops after 5 seconds
remove the memory then make a clean or replace a new memory
Posted on Jun 25, 2009
  • 3 Answers
SOURCE: My Acer Aspire One 150 shuts down automatically
You didn't say what you have tried, but if you go into the control panel, select > Power Options, ithen n the left side panel > "Choose when to turn off the dispaly." Adjust the setting according to using the battery or plugged in. You can also pick "Change when the computer sleeps" and make adjusments there.
Another thing you can be aware of is the life of the battery. If it is low, it will shut down also.
Posted on Sep 12, 2009
EMKartha
  • 163 Answers
SOURCE: computer freezes after about 5 minutes of turning
Looks like the Laptop is running some backend program which could be either a service, an application running at the stealth mode, or a driver program that seems to seize the Memmory resource allocated to the Kernal. Did you try check the system log by going to Start - Run - eventvwr.exe wherein you will find two heives namely Application and system. On the second start try to go through this event viewer which is opened as i said before and find out if you can locate any memmory related critical error or any application related critical error which lead it to a hung state and a restart registered later.
If you cant find that please boot in a safe mode and see if this is happening. It should not happen ideally speaking. Still if this is happening, try to restore the OS or run the repair disk of Acer Aspire. This should resolve the issue. Still if you cant resolve this issue its surely due to a hardware problem. I would advice you to go ahead tappering the chances of problems starting from an OS monitoring to Hardware Troubleshooting as per the steps i have explained here. Good Luck.
Posted on Feb 14, 2010
SOURCE: I have an Acer Aspire 4520, Will not turn on.
IT COULD NVIDIA DISPLAY IC PROBLEM,GET IT REPLACED.
DHARMAKKAN
Posted on Mar 21, 2010
How do I get into my bios when F2 won't work
Try tapping the Delete key instead.
It say here you use F2, but you have to do a complete shutdown rather than a restart. You have to keep tapping as soon as you see a logo or life!
http://community.acer.com/t5/2014-Archives/How-do-I-access-the-BIOS-on-a-Acer-Aspire-V3-571G-9636/td-p/13751
  • How to Manually Reset a BIOS Password for Acer ' Business ... yourbusiness.azcentral.com/manually-reset-bios-password-acer-18989... How to Manually Reset a BIOS Password for Acer. ... Acer: Aspire One 552 Service Guide; Resources. Minicircuits.com: The Prevention and Control of Electrostatic ...
  • How to reset bios password on Acer Aspire 5742 PEW71 ... www.youtube.com/watch?v=aNR7JZYl2PE
    • BY AFTER HOURS TV & PC REPAIR
    • 2 MIN
    • 149K VIEWS
    2014-01-27 · How to reset bios password on Acer Aspire 5742 PEW71 laptop After Hours Tv & Pc repair. Subscribe Subscribed Unsubscribe 4,157 4K. ...
  • How to remove BIOS password for Acer Aspire 57** Series ... www.youtube.com/watch?v=ox57qUf33Es
    • BY SAMIR
    • 4 MIN
    • 161K VIEWS
    2011-05-11 · How to remove BIOS password for Acer Aspire 57** Series ... How To Remove BIOS Password Using CMOSPWD ... Acer Aspire 5532 Bios Password Removal ...
  • How to Reset a BIOS Password on an Acer Laptop ' Techwalla https://techwalla.com/content/reset-bios-password-acer-laptop How to Reset a BIOS Password on an Acer Laptop. Submitted by Robert Ceville. ... If you do not want to use the command prompt to reset the BIOS password, ...
  • Removal of the BIOS password from an Acer Aspireone ... https://www.evolutionelectronics.net/node/42 Acer Aspire One 756: The metal pins (i.e. jumper) are labeled "CMOS". Next to the 2nd memory slot.
  • Remove a BIOS Password - custhelp.com acer.custhelp.com/.../detail/a_id/29353/~/remove-a-bios-password Remove a BIOS Password . How do I remove my BIOS password? ... as charges may be required for Acer to remove HDD passwords. Share. Delicious ; Digg ; Facebook ;
  • Apr 16, 2016 | Acer Aspire Computers & Internet
    How can I get my Acer Aspire 5733-6410 Laptop to Boot Up
    Well not enough information , ALT PLUS F10 at the start logo Will send you to recovery factory mode
    work it out from there ,to what you want to restore
    May 31, 2014 | Acer Aspire 5600 Series 5630-6951 Laptop
    Starts, 3 secs, turns off, restarts 3 secs repeats
    Try removing the battery and restart. Could be a bad memory module, fan not working, CPU going bad, graphics chip overheated and going bad. I assume it is out of warranty so you might have to take it to a repair shop.
    Feb 13, 2014 | Acer Computers & Internet
    My acer aspire 5733 won't let me navigate to
    f12 key may gone faulty, you need to attach a external key board
    May 16, 2013 | Computers & Internet
    Well lastnight i set my laptop down and went to go do somthing for about 10 minutes i cam back and it was a blue screen, not thinking anything about it becuase this laptop has done it before i just powered...
    you need to reinstall your operating system your files are corrupt so it will stay in constant boot mode until you reinstall if it doesn't work let me know
    Mar 04, 2013 | Aspire Acer 7520-5071 Notebook
    My network controller on my acer aspire 5733-6424 is not functioning
    if you have enter to the internet from another computer, go tu the -
    http://us.acer.com/ac/en/US/content/drivers - enter your acer model and get all latest drivers and softvare... just update your network driver
    Feb 19, 2013 | Acer Aspire 5733-6424 Intel Ci3-370M...
    Acer aspire 5333 webcam drfiver
    Search the Acer website.
    Find the appropriate drive using the model number of your laptop.
    Take care!
    damnor01
    Apr 28, 2012 | Acer Genuine Aspire 5250 5333 5733 5733z...
    Acer Laptop pew71 aspire manual
    Hello,You can download your "Acer Laptop PEW71 ASPIRE" manual in Acer website.
    Best regards,InJ3CtOr.
    Aug 09, 2011 | Computers & Internet
    Computers & Internet Logo
    773 people viewed this question
    David Payne
    David Payne
