Question about Philips Magnavox MT1905B 19" TV
Need he;p tv is set up like it was back in the store and brand new.can not find reset button
  • Sharon Stollings Jun 06, 2007
    my tv was in demo mode.pushed up and down volume buttons on the tv at the same time and NOW WORKING
    THANKS
Need remote code for element television elefw195...
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily......
http://electro-medical.blogspot.com/
Apr 09, 2016 | Element Televison & Video
I have a 32" GE XS Stereo- Commercial Skip T.V. Model# 25GT270 Made in Mexico Aug 1999 > No remote. I purchased a GINORMOUS universal remote control new in the box from 2nd hand store. No instructi
:),a tv does not use either play or stop commands,in most universal remote u need to set the apropriate code for the tv set so u can use volum,chanells and other tv specific commands.
In order to do that u need the manual!!! many china remotes have printed on the back of the box a long list or have a very thin paper hide in the box eith several codes.
good practice:a universal remote use a SET button and a TV button,that if u press at the same time will enter the mode set tv code.if u don,t have the code,press once again set after set+tv,will enter the scan mode,keep the remote pointed on the tv,if lucky after a short time(1 minute) the remote scanned and found the tv so u can enjoy some commands.many tv set have comun codes that will make a remote with no apropriate set to stop in a not full mode,so u only will acces part of the commands...post video and fotos
best regards
Oct 28, 2014 | Televison & Video
My brand new LG 47LE5400 has no audio
I would verify that the volume control built into the television will not turn the volume up or down. If it does then the remote is causing a problem. If the button on side of tv will not raise volume up or down, I would contact the place where the set was purchased and have them either send out repairman, or either give another set. I guess this would be pretty much up to you since it is a brand new television. Hope this helps.
Regards, Robie
Jan 22, 2011 | LG 47LE5400 47 in. TV
Locked out of a 60 inch tv need a code. We need the code to get back into the tv to set it up.
Please follow the below steps
1. Press menu and press right or left button until the Lock menu appears
2. Press up or down button to display code entering mode.
Blocking reset status:
Set four digit code by pressing number buttons and presses ENTER
If code already stored:
Press the four digit code and press ENTER.
3.If you cannot remember the stored code press recall button four times within 5 seconds.
PIN will be released (blocking reset status restored).
Thanx
Jul 26, 2010 | Toshiba 42H81 42" Rear Projection...
The tv only talk in Chinese characters! i am trying to tune in my TV in a new houe, an the language setting (on screen TV menu etc) has changed to Chinese. As i cannot read chinese, i cant follow any...
Try unplugging the tv for the night, or a day, it should reset the settings to defaults, if the settings are still in chinese, look for a reset button on your tv. there maybe a memory battery inside the tv that keeps the settings in memory. But its unlikely, so unplugging for a night or a day should get rid of the issue and it should go back into English, unless the tv was made and purchased in china or japan where the language would be the default, original setting..
Aug 03, 2009 | Televison & Video
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Bought remote from dollar store no instruction
I've bought the same remote control w/ out brand, and I've been using that for a long time. When I bought, it came w/ a manual w/ many codes... but u can use the general search that for me is better.
For example, you wanna fix a TV
1st - press SET button and the TV1 button AT THE SAME TIME (the RED light might be turned ON)
2nd - Press the SET buttton, and you'll see the red light shine, twinkle. (it means that the remote control is trying all codes)
3rd - while the red light twinkle, try pres the ON/OFF button... you should press the ON/OFF button many times, and when the TV turns off is because you found the code, so press TV1 button to stop the research in your remote control.
***PAY ATTENTION!!! If you don't stop the research at the same time that the remote control find the code, you'll lose the code... so you need restart everything again.
I hope it gonna help you!
Oct 12, 2008 | Televison & Video
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
How do you reset forgotten parental control password?
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Oct 23, 2006 | Daewoo DTQ-13P2FC 13" TV
Philips Magnavox MT1905B 19" TV Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
