Question about Exercise & Fitness
Pro Form 745cs Treadmill does not incline
The number increase but the machine does not incline.
  • fmnsdorris Jan 12, 2009
    Thank you for your response but it wasn't the problem. We can make it incline by using a jumper on the circut board. It just doesn't do it by its self.
  • adorko Jan 13, 2009
    I have the same problem. The number goes up and it raises a little but not to where it needs to. I think the motor for the incline is bad, but I am not sure.
My jack screw needed to be adjusted. It is a long screw about 1" in diameter. If you take the cover off, you should clearly see the jack screw. If you adjust the incline with the cover off, you should see the jack screw rotate. One end of the jack screw may have come out allowing the screw to rotate freely and not raise the incline. If you can reengage the screw, it may work. I don't know if this will help, but I needed to do it.
Posted on Jan 11, 2009
My sisters roller broke of the back end and detached from the plastic end can this be fixed?
Posted on Oct 10, 2009
After recalibration, incline still doesn't work
Some elevation motor has 3 things:
1) Capacitor test it.
2) Limit switch for up and down,
3) Relais for up and down.
You must test it before to replace the complete elevation motor.
4) See if there are 110Vac to the terminal of the motor, if there are the motor is Faulty, If not test the 3 steps mentioned before.
You can go to Treadmill Doctor
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 08, 2017 | Proform 740cs/745cs Treadmill Walking Belt...
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Ifit treadmill stuck on highest incline
RUN inmedaitely the software calibration for diagnose, troubleshooting and fix it. Now that machine is running in slow speed.
sincerly. God bless you
Apr 23, 2012 | Proform 740cs/745cs Treadmill Walking Belt...
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
My treadmill will start and you can increase speed and incline but fan will not work and you can not decrease speed or incline. And I can not stop the treadmill. I have to emer. stop.
I'm not sure if this will help.
First I was unable to identiy your model. Star Trac makes 'S Series' treadmills and Pro Tread DC (5500 Pro S model) treadmills. Can you be more specific on your model?
Second. I have used Star Trac customer service in the past and they are the best. They are responsive, and knowledgeable, and will provide troubleshooting flowcharts to help you solve your problem. I highly recommend giving them a call.
Hope this helps,
Kurt
Jan 21, 2011 | Startrac Fitness Products Star Trac Pro S...
I cannot get it to incline. It will say it goes from .5 to 10 and not incline at all
First perform an incline calibration. The procedure is outlined in your users manual.
It is a simple procedure. Insert the safety key and start the machine in motion. Press the incline up button. While the numbers are increasing remove the safety key.
Now reinstall the safety key, the machine should incline to maximum then lower back down to minimum.
Now you can operate the treadmill, the incline should work.
Jan 04, 2011 | Proform CrossTrainer Treadmill
My treadmill will not incline. when you press the
Wondering if you found a solution to this problem yet? I seem to have the same situation with my 730cs treadmill. It is inclined and will not move up or down...thanks.
Mar 02, 2010 | Proform 730 Folding Treadmill Model...
Treadmill not working properly. Incline keeps slipping.
there is a plastic spacer at the rack area on the incline mtr- this white plastic spacer has broken, only recourse u have is to unplug the white wire on incline mtr, and never have a incline, or replace incline mtr when you find out how much the mtr is you might want to walk with out incline- if you was in my area, I have them cheaper
Jan 07, 2010 | Proform Quick Burn Pro Treadmill with 12...
Will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Nov 29, 2009 | Proform Quick Burn Pro Treadmill with 12...
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Exercise & Fitness Logo
1,719 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
