Question about Brother DCP-7020 All-In-One Laser Printer
Hi i have a printer that always need to dust the frum & i was wondering how to dust it & where is the drum located
  • 148 Answers
Best way is to use a vacuum and a paint brush and lightly brush and vac up dust. Careful not to damage some of the wires that may be under where the drum is. Never use canned air, I have seen many machines damage by a customer using canned air inside of a machine..
Hope that helps...
Lbcoaster
Posted on Jan 10, 2009
  • 215 Answers
The drum unit is what you install the toner cartridge into. if you've changed toner, you've pulled out drum unit b4. open front cover, pull out drum unit and look at the top of it. you'll see a blue plastic tab. look down inside that slotted opening and you will see what look like guitar strings. i personally have used canned air to gently blow the toner/dust off of those strings. just be careful. last, but definetly not least, notice what side that blue tab is on, take the tab and slide it side to side several times, making sure when done to put it back on the side it was. that should do it.
hth,
razors
Posted on Jan 29, 2009
Copies come out with dark/grey streaks on both edges and a lot of black dust inside the front cover
hi there . sevsral rssons cause that . first you have to clean the toner tank which located down of the drum unit if you dont have the experiance you have to call your technical to do it for you .
another propable reason the drum unit need to clean and you will get it out any way in the first step
Aug 21, 2015 | Kyocera Mita KM-1650 All-In-One Printer
Am machine drum damaged(pit marks)my machine model cannon6570i
Step1 Put on your latex gloves to protect the drum from skin oils. Cover a firm, stable working surface with a few sheets of clean newspaper to prevent spreading toner dust over your work area.
Step2
Disconnect your Canon copier from its power source and allow it to cool down for several hours if it has been used recently. Locate the access door to your toner cartridge and drum, typically located on the front or side panel depending on your specific model.
Step3 Remove the toner cartridge from its holding tray by lifting from both sides and pulling it up gently. Gently shake the cartridge to remove caked on dust, then place it on top of the newspaper sheets. Using your vacuum's hose attachment, clean away any toner dust from the cartridge's holding tray.
Step4
Lift the hinged door behind the holding tray to expose the copier's drum. Turn the spindle to the side of the door to rotate the drum. Apply a microfiber cloth to the outside of the drum as it rotates to clean away toner dust. Continue until the drum is as clean as possible.
Step5
Close the hinged door and replace the cartridge in its holding tray, ensuring that it is oriented the same way as when you removed it.
Step6
Reconnect your copier to the power source and make a test copy to ensure proper function.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Apr 01, 2014 | Canon Office Equipment & Supplies
I have a problem with the colour prints...there are different kind of lines all over the page..how can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
Drum light still flashing after replacing drum
Please remove the drum unit and clean the contacts of the drum unit and its chip on the printer. it should be located under neath the cover.
It just due to moisture and dust from old drum thats not reading the new unit. or try to go in the menu and rest drum supplies status.
Sep 23, 2010 | Brother HL 2140 Laser Printer
Brother DCP-9040CN, when printing color splotchy in one area
Try this:
2.3 Drum Unit Cleaning Mode
This mode is to remove the dust attached on the exposure drum.
When white spots appear on the printout, perform this operation to
remove the dust by using the drum cleaning sheet.
<Operating Procedure>
(1) Load the drum cleaning sheet into the MP tray.
(2) Check that the status LED lights in green and press the and
Clear/Back buttons at the same time. “DRUM CLEANING” will
appear on the LCD.
(3) Press the Black Start button. The machine starts cleaning the drum
unit. “DRUM CLEANING / PLEASE WAIT” appears on the LCD
during cleaning.
(4) When finishing cleaning normally, “DRUM CLEANING / COMPLETE”
appears on the LCD.
(5) Press the Stop/Exit button so that the machine returns to the ready
state.
Oct 09, 2009 | Brother DCP-9040CN Laser Printer
Aficio 1085 toner pread in drum area
the blade is not sitting correctly either you have used a bad one or the mechanism is not adhereing closely to the drum, removed the uit and rotate towards you sprinkle a few toner if you can still see a remainder toner that was not yet scraped then the prob is really in the cleaning unit, either the blade or the plate,
to ensure have you consider changing your drum? it could be exhausted already...
no other way around it
Nov 28, 2008 | Ricoh Aficio 1085 Laser Printer
Konica 7020 copier
f-26-3 is a toner density sensor problem. clean the sensor. It probably got dirty when you took the drum out. It senses how much toner to dispense. Lawrence Its on the d.v. assembly by the drum
Mar 22, 2008 | Office Equipment & Supplies
Dust on Drum...
I had this problem too. I took out the drum and vacuum the drum with a vacuum cleaner ( no brush ) while at the same time manually rotate the drum cyclinder. It worked. After a month or two, you might have to do it again. But everytime, it solved the dust problem.
Nov 23, 2007 | Brother MFC-7820N Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
74 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
