Question about Onkyo Ht-r510 600w 6.1 Dts Home Theatre Sys. W/powered Sub, All Speakers, Bundle
Onkyo HT-R510 left side speaker garbled
Left front side speaker is garbled even when I swap sides with the speakers the speaker plugged into the left side input is garbled. I have replaced the speaker wire and the problem persists. How do I proceed to isolate an fix the problem?
    Sergeant:
  • 344 Answers
Out put transister could be fried ,Or the speaker is blowin,
Posted on Nov 29, 2012
jomabug76
  • 1148 Answers
SOURCE: Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Posted on May 15, 2009
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 16 Answers
SOURCE: 7.1 speaker setup: no sound coming from right front/surr speakers
check the patch cord the right side might have went bad
Posted on Aug 20, 2009
  • 5 Answers
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Posted on Feb 13, 2010
Intermittent speaker performance - receiver issue - not a speaker issue
Matt,
Have you checked/cleaned the leads on each speaker as one bad lead or speaker can pull/push extra power from/to other speakers causing shorts, this is likely not the case but could be the easy fix. Try cutting one speaker out at a time rotating which one is disconnected to see if this fixes the issue and possibly points out either a bad speaker or connection.
Dec 04, 2013 | RCA Onkyo Ht-r510 Receiver 6.1 Channel...
Onkyo HT-R510
have you tried to reset it to factory defaults yet? If it has a vcr button on the front, then hold the vcr button and press power...it should say reset on the front. Might not help, but worth a try.
Dec 04, 2013 | Onkyo TX-SR601 Receiver
Onkyo HT R520 Home Theatre reveiver/amplifier problem
If you have isolated the problem to the receiver/amplifier, it will be necessary to find out why that output is dead
Oct 04, 2012 | Onkyo Audio Players & Recorders
Durabrand Home Theater System Model HT-3917. It was playing ok a little crackle from the front side speakers for a couple days now and it just went off. I checked the fuse no,I checked the power strip and...
You (we) still don't know if the speaker or electronics are at fault. Swap the speakers left-to-right. Use test tones to test all channels. Could be a loose speaker wire, too.
Jul 24, 2011 | Durabrand HT-3915 System
I have an Onkyo Hts - 580 Theater in a box sytem. Lately I noticed no output from the front left speaker, alos no output when test tone is used. Pkease help.
you might want to switch the speakers that youre using. e.g front left put it to front right and vice versa to isolate if the speaker has the issue or the amplifier terminal.
if the left speaker works on the other terminal then its a terminal issue.
Feb 02, 2009 | Onkyo HT-S580 System
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
3 speakers dont work
Check to make sure that Speaker B is not pushed. It's on the front panel on the bottom left.
Dec 14, 2008 | Onkyo HT-S780 System
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Damaged Speaker Connection on Receiver
try swapping the speakers to see if your right speaker works on the left side.Is the jack where it plugs in loose?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
May 01, 2007 | Onkyo HTR500 Receiver
Onkyo Ht-r510 600w 6.1 Dts Home Theatre Sys. W/powered Sub, All Speakers, Bundle Logo
118 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
