Furnace is not turning on
We have a intertherm 14 year old propane furnace.In the summer when it was like 90 degrees outside the blower turned on and would not shut off,so i turned of the breaker to it.Since then we have used the furnace with no problems untill recently.We did not use the furnace for a short time due to money issues so we turned the thermostate down. When we went to use the furnace again we turned up the thermostat but it did not turn on like usual.The pilot is lit and the furnace hums like usual but the blower does not turn on like before.We were told it was the thermal coupler so we bought a new one and had it put in,but still did not work.Do you have any suggestions.We are very low on funds so any help would be great.I have been taking advantage before payed almost 400 dollars to a professional to come to my house with a different furnace to fix it.Did this and did that and then found out through someone the heat exchanged was cracked needed a new furnace and could have killed my family.
If you have fuse in your furnace check the fuses if some of them got busted.
If your filter is too dirty, it could cause your "fuse" to blow up because
the fan is having hard time to **** air into it. Therefore the fuse will
overload and will burn. I have a problem (won't turn on) with my furnace just two ago.
I thought my thermostat had a problem, so I bought a new one and
replaced the old one. After reading some of the solutions here I found
out that I can remove the cover infront of the thermostat, so i checked
and pryed out the front cover and found a small door where all the electrical
connections were and the 4 fuses in it. That's where i found the fuses
and replaced the two burned ones. When checking the fuses,make sure
you turn off the furnace breaker, to avoid getting injury or electrecuted. I bought
4 new fuses to Lowe's hardware and stalled the new fuses. I solved my problem,
now my furnace heater is working.
Posted on Mar 16, 2009
  • 82 Answers
Sounds like you have a bad fan limit. they will sometimes kick on in the summer when the temp gets high enough. now it sounds like it is not working at all. it is usually mounted with a metal square cover over it removing the cover would expose the dial this it what turns as the furnace heats up and kicks on the fan . turning it by hand will check to see if fan will kick on(turn a lttle clockwise)
Posted on Jan 10, 2009
Furnace goes out when blower should start
There is a sensor called a pressure switch that is attached to the area of the blower motor for the exhaust fan. It is bad or plugged.
Nov 16, 2015 | Heating & Cooling
Goodman furnace fan cylcing
The fan switch is set to turn on at approximately 125 degrees and run until the heat exchanger temp drops to around 105 degrees. With age the sensitivity of this switch varies and summer heat can cause the switch to turn on if the outside temp is over 100 degrees. Only the fan is running, not the burner but you can shut off the power to the unit if this is an issue.
Aug 27, 2012 | Heating & Cooling
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
I have an old 1973 Mac 1199 Intertherm propane furnace The burner will come on and it takes a long time for the blower to come on Sometimes the blower wont come on at all and after awile the burner will...
Replace the fan limit switch. It is sometimes mounted in the ductwork and sometimes just below the ductwork in the furnace cabinet. Note where the little arrows are pointing to on the temperature scale so you can set the new control to the same as the old. Usually this control is made by Honeywell and may have three wires going to it.
Oct 20, 2009 | Intertherm Heating & Cooling
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Intertherm propane furnace makes popping sound when running
It sounds like you have a possible hole in the heat exchanger. Turn the heat off and turn the fan on. If you feel any air coming back out of the heat exchanger, you have a hole. A yellow flame is not a good sign. I would even consider having a service professional come out and take a look.
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Jan 18, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
342 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
