Question about Samsung Televison & Video
Samsung TXS3082WHX/XAA Tv wont turn on by remote or by pushing switch.... taking a ticking noise while plugged in...... any ideas?
    Top Expert:
  • Samsung Master
  • 74,482 Answers
The relay cuts inside the TV after swich on. Should be some short circuited component/board inside it. Check and replace it. The click sound you hear is of the clicking of the relay. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 29, 2012
5 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: My Samsung LN52A550 LCD TV will not stay on.
The ticking noise usually comes from the power section of the tv. Usually it is a capacitor failing. As far as the cost of repair this can go either way ie cheap or expensive. It will dpend on what exactly has failed and if it requires a board replacement or just a part.
I'm going to assume this isn't under warrenty anymore. It is covered if it is. You need to get some repair estimates from Samsung and any tv repair shops. Then keep and eye out for a replacement. Make sure you include any shipping costs or other costs when you are totaling up the estimates. If it gets close to the replacement cost then you will have to choose if you want a new tv or have a repair done.
Posted on Jul 07, 2010
  • 21 Answers
SOURCE: when i turn my samsung 40 inch tv on it makes a
To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Posted on Feb 22, 2010
Testimonial: "thank you your spot on"
SOURCE: samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Posted on Mar 29, 2010
  • 3 Answers
SOURCE: I have a 50 inch Samsung, Model FPT5084X/XAA that won't turn on.
Seems to be a chronic problem for this model. My list of service calls with Samsung is quite lengthy.
Posted on Apr 12, 2010
Samsung DLP fan noise, TV won't power up
Sorry, not a solution. I am here with same question. It has happened just as you said 4 times in the last two years.
Dec 06, 2013 | Televison & Video
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
I have a HDTV Samsung TV, Model #TXS3082WHX/XAA and I would to connect my desktop to the TV. Do you know what cables are needed?
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
Feb 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Samsung lnt4065fx/xaa with 100's of colored lines
Sound like one of two things: A test screen, or a broken TV. More likely than not, your television is broken. Try hitting TV/Video on your remote, and if that doesn't work, power the TV off, unplug it, and plug it back in. If none of the works, it's time to call a repair man.
Oct 29, 2009 | Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
SAMSUNG TXS3082WHX/XAA Won't Turn On
All of these tv's are board replacement only the individual parts are not available. The boards can cost anywhere form $200 - $400 each. Even if you do it yourself it is still an expense, if you get the blink code i can point you to the correct board. These sets have different boards even within the same model range. One of the first diagnostics is does the back light come on, if not then you either have a balancer error or a bad bulb in the panel. Why i suggest this is because it is the most common problem. If it is the bulb in the panel you have to replace the whole panel, the bulbs are not available as an individual part.
Sep 02, 2009 | Samsung TX-R3080WH 30" TV
My tv txs3082 blink constantli
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Jul 22, 2009 | Samsung TX-R3080WH 30" TV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Televison & Video Logo
109 people viewed this question
Henry  Thomas
Henry Thomas
