Question about Canon IXUS V2 Digital Camera
E 18 error lens half way out. tried all fixes( w/o disassembly) is there anything to be aware of when disassembling? and is it even worth my time.
  • timryan Jan 11, 2009
    help gratefully received !
Try holding sown the start button and the bin/timer button at the same time while the camera is set to look at photos rather than to take photos
Posted on Jan 26, 2009
How to disassemble a Makinon mc zoom lens
first off, you need special tools to get at the inner elements of a zoom lens - i've been working on lenses for 20 years, and i still don't have every tool needed sometimes :-)
second, makinon lenses are not really worth anything, even if they are in perfect condition - my advice is to buy a better zoom used that is in perfect condition already, since you would have spent that money in tools to try and clean this one, and everyone screws up the first lens they ever try to take apart...
some good lens brand names are sigma, tamron, kiron or any with the same camera name as your camera (canon, nikon, etc)
stick with japan made optics - can't go wrong usually.
good luck...
Nov 30, 2014 | Cameras
Camera says lens error, restart camera...
Hi, On Canon camera's that error is typically seen when the camera's been dropped and the lens is now out of place. For the A490 specifically that's something that can't be fixed as it's such an inexpensive camera and fixing that problem, if it can even be fixed, costs upwards of $300.
Aug 29, 2011 | Canon PowerShot A490 Digital Camera
When i turn on my camera it says lens error and the lenso stays half way out
Hi.
If the lens do not extend completely, then problem is lens itself.. When this happens the motor is unable to retract or to extend the lens either because one of the lens rings is damaged, or because of dust inside lens rings.
Sometimes lens error occurs because batteries are nearly drained and insufficient power to lens motor. This will cause the lens rings getting out of alignment and you get jammed lens. In other cases the lens gets jammed either because of dust or dirt or because of a mechanical problem.As a result the camera freezes with lens half of the way out.
In some case the len
s can be unjammed manually (see the tips below), more commonly the lens and the camera must be disassembled and there is no other way to fix the problem.
Try the tricks below. They rarely work, but you never know:
Test always with fully charged batteries you need as much power as you can get to unlock the lens. Ensure that batteries are Alkaline or good working rechargeable.
If there is dust or sand in lens blow air with a compressor on top the lens..
Sometimes methods like helping the lens movement while turning camera on and off works, but this methods can do more damage to the camera. Help out the lens while turning the camera on.
Remove the battery, point camera to the floor and put back the battery while holding on button and still pointing to the floor. Turn on this way and see if it works.
Connect camera to USB (that gives extra +5V power) and turn on still pointing to the floor.
You find some more detailed hint using the links below. The links refer to digital cameras (no film). In your case disregard all the parts that do not apply( e.g some hint is for lens not retracting - the cause of the problem is the same and I reported the link).
Lens not retracting on digital camera.
Fixing Lens Error.
Lens Error.
Most of the time the lens error must be repaired disassembling the camera. Sometimes lens rings must be replaced. If you need a quote on repair see:
Repair.
Regards.
Ginko.
May 31, 2011 | Nikon COOLPIX L18 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
There is a small black tube like piece that has come loose inside my lense and I need instructions on how to disassemble. It has something to do with the zoom I think?? Nikkor 18-55 ED
The small black tube piece is a sliding light baffle which has come loose. Zoom lenses are very complicated to disassemble, and you have to have both the knowledge, experience, and the right tools to disassemble a zoom lens.
The tube should never have come loose in the first place, so I would classify this as a product defect. Contact Nikon, fully describe the problem, and insist that they repair the lens at no charge (although you will have to pay to ship the lens to their repair center).
Apr 26, 2009 | Kodak Pronea 24-70mm IX Nikkor Lens
Canon Powershot S2 IS Disassemly guide?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it without disassembly. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 22, 2009 | Canon PowerShot S2 IS Digital Camera
Nikon coolpix p2 lens error
You can disassemble the lens and clean the dust. Here are some photos of the disassembled P2 Lens http://fixit.limewebs.com/p2/
Aug 21, 2008 | Nikon Coolpix P2 Digital Camera
Lens focusing problem
I doubt that there is anything you can do yourself. Are you willing to disassemble the lens? I wouldn't be willing to do so.
Take it to a camera repairer and get a quote to see if it is economical to repair or cheaper/easier to replace.
Good luck.
Jan 04, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Canon IXUS V2 Digital Camera Logo
48 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
