My MHC-GNX60 Automatically shuts down when I turn it on?
When I plug it in it turns on and stays on so its getting power but its when I push the on button it turn off?
  • 39 Answers
SOURCE: The System shuts off automatically
System detects power rail irragularities.E.g +5ve the fault is in power supply section.
Posted on Dec 17, 2007
  • 4 Answers
SOURCE: I cant turn volume up all the way on my Sony MHC NX 3av
Make sure your cables are not touching each other, and/ or that they have been inserted into the right terminals on the speakers. This should rectify the problem.
Posted on Aug 07, 2009
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID uttamkholiya@yahoo.com
any sony music system problem
Posted on Nov 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: My Sony stereo system keeps
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 01, 2011
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
Sony MHC-GNX60 what does speaker b mean and how do you fix it
I pressed reset STOP + ENTER + POWER speaker b went away sound came back.
Feb 22, 2013 | Technics Audio Players & Recorders
The power button on my HP monitor keeps getting a message saying "Power button lockout" and the monitor will not turn off whenever i push the power button it just goes to sleep and i have to unplug it and...
Hold down the power button on your monitor, with the power on, for approx. 25-30 seconds and the monitor will shut down for good. When you will start it again, wait at least an hour, the message will be gone and the monitor will work as intended.
Jun 23, 2010 | Computers & Internet
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
When trying to power up hear 3 beeps and camera turns off.
Make sure the batteries are good and in right. If it keeps doing it you might be having a problem with your lens opening up and staying open, I had a camera that did that to me, and the lens had been knock and wouldnt open properly, check that out. The lens was out of range from normal and would automatically shut down
May 09, 2009 | Cameras
Power shuts off when CD/tuner/Tape Button is pressed
take out any extra speakers unplug and replug,and if problem continues your fuse is broken.
Apr 02, 2009 | Sony MHC-GX450 CD Shelf System
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Dec 17, 2007 | Sony MHC-GX9900 Shelf System
Worth fixing?
Open the cassette deck and use a pen to push the heads down. After this, it would probably work better to avoid using the deck.
Aug 12, 2007 | Sony MHC-RXD3 CD Shelf System
21 people viewed this question
 Grubhead
Grubhead
