Question about Samsung CLP-315W Laser Color Printer
Samsung CLP-315 paper printout is dirty - Samsung CLP-315W Laser Color Printer
namizhka
  • 148 Answers
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Posted on Sep 16, 2008
beazleybub
  • 3 Answers
SOURCE: Samsung CLP-315 paper tray position
There is absolutely nothing wrong with your printer. The tray is recessed during packing to reduce packing space for shipping. When you pull out your paper tray for use for the first time it expands to accommodate the paper. It can be collapsed by pushing the little blue tabs that say press here to make it flush again but you would only need to do this if you were using a non standard paper size.
Posted on Feb 08, 2009
snowman533
  • 33 Answers
SOURCE: SAMSUNG CLP 315 paper jam
the printer may be detecting dust or something on the sensor, and detecting it as a jam
try to get the sensors cleaned, tell us how you go
Posted on May 19, 2009
CompuFirm
  • 89 Answers
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
Posted on May 26, 2009
nakshatraipu
  • 241 Answers
SOURCE: Samsung CLP-315 eats toner. Cartridges last almost
YES WE HAVE PERMANENT SOLUTION FOR CLP 315
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Posted on Nov 18, 2009
My samsung clp 315 printer, lights RED and AMBER together when i switch it on.
my samsung clp 315 Red light blinking & in printing a Horizantal line is came in centre of the paper
Jun 22, 2011 | Samsung CLP 315 Laser Printer
I need a paper tray for a Samsung CLP-315, where would I get it ?
use this link to purchase online
http://www.ci-online.net/cv/index.php?category=Printer+Accessories&manufacturer=Samsung
May 29, 2011 | Samsung CLP 315 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Samsung 315 Color laser printer acts like it's going to print, but doesn't feed paper. No paper jam...
Sounds like you have a roller turned glossy.
Open your paper feeder drawer and locate the pickup roller. It's rubber, or like rubber and will either be glossy or a little dirty. Now take a light bristle toothbrush and clean the roller with alcohol, remembering to roll it as you clean. Allow to set dry for 20 minutes and try again.
Mar 07, 2010 | Samsung CLP 315 Laser Printer
Red light on samsung clp 315
Reset your printer using hardware module which works as permenent solution. info@nakshatraworld.com
Jan 12, 2010 | Samsung CLP 315 Laser Printer
Samsung clp 315 paper stops 3/4 during printing
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Dec 01, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315 is overheating and paper is jamming
OVER HEATING IS DIFFERENT AND PAPER JAM IS DUE TO OPTICAL SENSOR PROBLEM. kINDLY TAKE IT TO AUTHORISED SERVICE CENTER.
Nov 16, 2009 | Samsung CLP 315 Laser Printer
Is there any way to print paper sized 3.5" x 4.875" on the samsung clp 315?
After setting the correct sizing parameters in your printer properties, There should be a second set of loading arms sometimes you have to open the paper tray to see them but they should be there.Good Luck,Dana.
Aug 17, 2009 | Samsung CLP 315 Laser Printer
May 19, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315W Laser Color Printer Logo
165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
