Question about Schwinn 420 Elliptical Trainer
Schwinn 420 has error code E3
While using the equipment, after about 3 minutes the screen blanked out completely and then an error code, E3 came up.
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Error 3 (E3) on Schwinn 240 recumbent bike. How
No speed/RPM reading, Console displays "E3" error code
Check data cable integrity All wires in cable should be intact. If any are cut or crimped, replace cable.
Check data cable connections/orientation, insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place.
Check magnet position (requires shroud removal) Magnet should be in place on flywheel. If no magnet is present, replace the flywheel or the entire base unit (if unable to replace flywheel).
Check RPM Sensor (requires shroud removal) RPM sensor should be aligned with magnet and connected to data cable. Realign sensor if necessary ( 1/8" clearance between sensor and flywheel) if still error 3 then check the sensor with a multi meter unplug sensor leads attach meter to sensor connectors. Have someone by hand rotate the pedal while you observe the multi meter opening and closing the internal sensor circuit if no change in meter readings then replace the sensor.
Posted on Jun 01, 2010
What is an E3 code on a Culligan Medalist Series?
https://www.manualslib.com/manual/859287/Culligan-Medallist-Series.html?page=8
Quoting from link to free manual shown:
FAILURE MODE
There are certain conditions that can be interpreted by the circuit board as a failure of the drive motor or motor
position switch. Upon failure detection the control will cease further operation. A telephone hand set symbol will be
shown in the upper left corner of the display and the error code will be shown. Listed below are the different error
codes.
1. Motor Always Turning
Error code "E1" occurs when the circuit board detects changes in the motor program switch when the motor is
not supposed to be turning. The phone icon and "E1" will be lit in the display.
2. Motor Never Turns
The Culligan Medallist Series control is equipped to detect no change in the motor position when the motor is
supposed to be turning (motor or piston locked in a frozen position). The AccuSoft circuit board will apply
power to the motor for 20 seconds. If there is no change in the motor homing or position switch, the control will
power down for 1 minute. The circuit board will repeat this procedure two more times in an attempt to remove the
obstruction. If no movement has been detected, the control will permanently power down and a phone icon and
an "E2" will appear in the display.
3. Homing Error
Error code "E3" occurs when the circuit board detects when the control is unexpectedly in the home position.
The phone icon and "E3" will be lit in the display.
Error Display Cancellation
The error code display can be removed by removing the power to the control for 1 minute. After clearing an error
condition, the control will default to the factory settings when power is restored.
Apr 21, 2018 | Culligan Measuring Tools & Sensors
How to fix Error Code E3 on Schwinn 6710P treadmill
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jul 30, 2015 | Schwinn Exercise & Fitness
E-2 message on schwin 420
You may be able to reset the main board by detaching the ribbon connector, then reattaching it. Unscrew the four screws that hold the display panel, and you will see a ribbon connector and a round connector. Gently squeeze the tab in the center of the ribbon connector and pull it off. Wait a couple of minutes, then reattach the connector by gently pushing it into the socket. The display should show a boot-up process and then the normal blank screen with the prompt to select user. If the E2 error returns, repeat the process. If this procedure does not reset the board, you will need to contact Schwinn about possibly replacing the board. You can contact them by going to Schwinn.com (http://www.schwinnfitness.com/schwinn_fitness_us/customerservice.jsp) and select the "email us" link or call the 800 number.
Jan 30, 2013 | Schwinn 420 Elliptical Trainer
Error code 1 on schwinn elliptical 420
Dear Sir:
adjust the speed sensor see the diagram attached.
2) the main board can be faulty.
3) Run the software calibration.
5_3_2012_12_02_47_am.gif sincerely. God bless you
Apr 30, 2012 | Schwinn 420 Elliptical Trainer
My cannon printer shows Error Code 3. What does it mean please? Thank you.
Hello Gm,
Please check printer is turned on by pressing the "On/Off" button, you will notice the display prompt you for E3 (error 3). Press and hold the "On/Off" button for one second. The display will go blank and begin resetting the malfunction. Wait 10 to 15 seconds and restore power to the unit by pressing the "On/Off" button once more. Allow the unit to complete its cycling process and the error code should be gone. If the code persists, your printer will need professional maintenance.
May 19, 2011 | Office Equipment & Supplies
Error 3 showing
Follow the below mentioned steps to resolve the issue : 1. Ensure the Pixma is turned on by pressing the "On/Off" button, you will notice the display prompt you for E3 (error 3).
2. Press and hold the "On/Off" button for one second. The display will now go blank and begin resetting the malfunction.
3. Wait 10 to 15 seconds and restore power to the unit by pressing the "On/Off" button once more.
4. Allow the unit to complete its cycling process and the error code should be gone. If the code persists, your printer will need professional maintenance.
Apr 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Error 3 (E3) on Schwinn 240 recumbent bike. How can I fix it?
May 23, 2010 | Schwinn Exercise & Fitness
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Schwinn 420 Elliptical Trainer Logo
298 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
