Model 6ADP 8540 IX Type NGPM
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
SOURCE: i have a kenmore dishwasher mode 665.16032402
I was able to reset it using this procedure:
1. Crack the dook open
2. Within 3 seconds, press these buttons in this squence: Hi Temp Wash, Heated dry, Hi Temp Wash, Heated Dry
3. Close door
4. Press Cancel
That should clear the Blinking LED. It appears this is a common problem. The worst thing is they charge to come out for this.
