Question about DeLonghi Pinguino PAC-GSRU Air Conditioner
Unit beeps several times and gives warning symbol does not start
Unit does not work . upon turning power on unit beeps several times then displays a warning symbol. nothing works
    New Friend:
I have a Mitsubishi air con that has broken down like this twice because gecko's have gotten in and shorted it out. We had to have the circuits replaced at $1000 a pop. I think it can short out after a lightning storm too.
Posted on Nov 29, 2012
Laptop computer will not power up. using power cord and keeps beeping three times every time when powering up.cleaned ram contacts and reseated these. still no change!
Suggest Anti-Static Procedures need to be followed, laptop opened up, and cooling system cleaned.
Also suggest replacing Thermal Paste on Processor, and Thermal Pad on graphics chipset. (Piece of small copper sheet would be better)
What is the Dell's model name and model number?
Bottom of laptop.
Post back in a Comment.
Regards,
joecoolvette
Apr 05, 2013 | Dell Studio Computers & Internet
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Hi, we have a Honeywell ducted heating thermostat model t8602c2069. It has recently stopped working. This display panel is working so it's not the batteries, however when we turn it on heat does not come...
We have exactly the same problem as dmlauder! (posted 6th September)
What does the square symbol mean?? We have to keep resetting the outdoor heating unit...it works for a few minutes then stops
cate
Sep 06, 2010 | Honeywell Heating & Cooling
I have a playstation 3 system that worked for 1 day & the next time i attempted to play it,it did nt go past the initial playstation intro screen.The screen is grey with the playstation wave symbol...
Ok, follow these steps to cure your problem. Warning, you will lose saved game data!!
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you press it, then beep 5 seconds later and then once more another 5 seconds later and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep once when you press it, again 5 seconds later and then 2 quick beeps together. When you hear these 2 beeps release the power button
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then continue to the next step
Step 5. The options menu will display. Select option 5 "Restore PS3 System". The PS3 will re-install the software required and restart. Hopefully this will solve your problem
Hope this helps and thank you for using FixYa.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Power steering fails, light comes on at times after a cold start
The rack and pinion unit is failing. The internal seals are leaking. This is somewhat common in the Accords. A local alignment shop can repair this.
Mar 28, 2010 | 1991 Honda Accord
It beeping all the time
Does the red light flash over the battery symbol?
If so the batterries are either faulty or have a low level of charge or the charging circuit is faulty.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
Oct 05, 2009 | MGE UPS Pulsar Ellipse Premium 800 UPS...
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
DeLonghi Pinguino PAC-GSRU Air Conditioner Logo
513 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
