Question about Whirlpool MH1150XMQ Microwave Oven
Outter glass in microwave door shattered
I have a whirlpool microwave hood combination Stainless Steel model # MH1150XMS-# I have had for 2 1/2 years. I went to bed at about midnight last night and it was fine. When I woke up in the morning, the out glass in the door was shattered, but still intact. I called whirlpool and they acted like they had never heard of this happening and told me it would cost $185.00 plus tax and shipping just for the door and that a repairman HAD to replace it and I would have to pay for that too. Is this common, could there be a recall on it? I also have a stainless steel Frigidaire stove that has 4 small glass squares which tell you what temperature setting you have the elements set to (h, 7 , lo etc.) and 3 out of 4 of these are cracked. What is going on as I am dumbfounded. Please help. I think it will cost more to replace the door than the cost of a new microwave!
MicrowaveSvc
  • 9098 Answers
SOURCE: whirlpool GH518XP microwave hood combination Power off, wont come on at all
There are several parts which can cause the unit to be dead, mainly the fuse, thermostat, thermal cutout, or control panel. You can find critical safety info and disassembly tips ay my site via my listing here: http://tinyurl.com/yzjozk You can get handy exploded views and order any neededparts here: http://tinyurl.com/gv383 Not sure about that model number though - you might want to verify that.
Posted on Jan 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Inner 'glass' of door
The inner glass can and should be replaced. It protects the metal mesh screen from getting dirty, which can cause it to be damaged and allow microwave leakage. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: MIcrowave oven stopped heating - Whirlpool MH6150XMS
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 20, 2008
SOURCE: whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Posted on Jan 19, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Posted on Jun 06, 2009
Whirlpool recall
I just check and didn't find any posted for this model, are you having issue? What issue are you having? More information please. Thnaks
Aug 02, 2014 | Whirlpool Stainless Steel 1.9 Cu. Ft....
Help need replace glass panel in pvc
This door is radius and would be difficult to replace. Repair clinic claims the part is due in at the end of this month, I wish you luck on your search. I have not seen someone make this correctly as the metal supports at the bottom are attached to the glass and the stainless steel outer panel is just a panel stuck to glass.
Good luck
Feb 05, 2014 | Jenn-Air Microwave Ovens
What are the replacement bulbs for khms2040bss
W10208564 WHIRLPOOL MICROWAVE HALOGEN BULB REPLACEMENT
Aug 19, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
Glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Oct 09, 2009 | Bosch Microwave Ovens
Turn table shattered while making pop corn. Cuisinart ModelCmw100
You can order a replacement dish here. The dish shattered because the heat from the bag of popcorn was too much for it. If you look at the owner's manual for almost every microwave, they tell you not to put popcorn directly on the glass dish, but to put it on another plate.
The oven should be safe to use. Just look for any burned spots on the paint in the bottom of the cooking cavity.
Apr 09, 2009 | Cuisinart CWM-100 Microwave Oven
The door glass has a burnt discolored area
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Dec 17, 2008 | Whirlpool MH7130XE Microwave Oven
Replacing outer glass and stainless steel door on my jenn-air microwave oven
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 30, 2008 | Jenn-Air JMC8130DD Microwave Oven
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
125 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
